IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Car starts then dies immediately
Old 03-24-15, 07:56 PM
veblen
veblen's Avatar
Default Car starts then dies immediately
I recently bought an 01 is300 that had a bad oil leak. Found the leak was coming from the cam cap right behind the vvti pulley. I removed the throttlebody assembly to gain access and reseal it. Once I put everything back together the car will only start for a few moments as it revs to 2k and dies. It doesnt matter what I do with regards to throttle it always does the same thing and dies. Ive checked resistances in both the two position sensors as well as the throttle motor and theyve been in spec.
Im not sure what to do next. Any help or suggestions would be greatly appreciated.
Old 03-25-15, 04:55 AM
James4394
James4394's Avatar
Originally Posted by veblen
I recently bought an 01 is300 that had a bad oil leak. Found the leak was coming from the cam cap right behind the vvti pulley. I removed the throttlebody assembly to gain access and reseal it. Once I put everything back together the car will only start for a few moments as it revs to 2k and dies. It doesnt matter what I do with regards to throttle it always does the same thing and dies. Ive checked resistances in both the two position sensors as well as the throttle motor and theyve been in spec. Im not sure what to do next. Any help or suggestions would be greatly appreciated.
check the spark plugs I had that and i crushed one of the spark plug wires and cracked an ignition coil
finga11
26
06-08-23 09:43 PM
brandNV
Performance
06-08-18 03:58 PM
VIP161
Performance
11-16-13 07:46 PM
justablkv8
09-25-12 03:49 PM
michael024
01-01-12 09:48 PM
Quick Reply: Car starts then dies immediately
