IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Car won't start, help!
Old 05-06-14, 07:52 PM
MizzIS300
MizzIS300's Avatar
Default Car won't start, help!
For some reason my car died on me while I was driving in traffic on the freeway. This would happen sometimes, but I would just turn it right back on while driving and throw it into the correct gear and it would start right up. This time it didn't though so I pulled over. I tried to start the car and it would crank but not start. Someone stopped to help me try to jump my car, and at first it didn't help, but on the second try it did. So I drove off for not even a mile and the car dies again. And then my battery died. Once I got it towed to my house, I check the battery and it was charged, and I tested the igniter with a good one, and it still wouldn't start. My bf found that there was no spark at any cylindersgoing I'm not sure what the issue can be. It's not the cool packs because I just swapped them onto my new is300. A while back I installed the jdm cooling fans and found that my car would die at idle, so we unplugged one of the fans and it fixed the issue as far as I know(not sure if this is relavent to my current issue). There is an aftermarket alarm system that was installed on the car years before I bought it, and I never use it because it's so sensitive. Also I had a very sketchy locksmith make me a new key (it didn't even lock the doors when inserted into the door) this was done months before my car died though. And I just got a new key made and it still didn't fix any problems. My car also has 240,000 miles on it, so it's pretty old.
Please give me any advice that might help. Thanks!
Old 05-07-14, 03:33 AM
James4394
James4394's Avatar
Originally Posted by MizzIS300
For some reason my car died on me while I was driving in traffic on the freeway. This would happen sometimes, but I would just turn it right back on while driving and throw it into the correct gear and it would start right up. This time it didn't though so I pulled over. I tried to start the car and it would crank but not start. Someone stopped to help me try to jump my car, and at first it didn't help, but on the second try it did. So I drove off for not even a mile and the car dies again. And then my battery died. Once I got it towed to my house, I check the battery and it was charged, and I tested the igniter with a good one, and it still wouldn't start. My bf found that there was no spark at any cylindersgoing I'm not sure what the issue can be. It's not the cool packs because I just swapped them onto my new is300. A while back I installed the jdm cooling fans and found that my car would die at idle, so we unplugged one of the fans and it fixed the issue as far as I know(not sure if this is relavent to my current issue). There is an aftermarket alarm system that was installed on the car years before I bought it, and I never use it because it's so sensitive. Also I had a very sketchy locksmith make me a new key (it didn't even lock the doors when inserted into the door) this was done months before my car died though. And I just got a new key made and it still didn't fix any problems. My car also has 240,000 miles on it, so it's pretty old. Please give me any advice that might help. Thanks!
sounds like the fuel pump
Old 10-05-14, 09:07 PM
Schmitt605
Schmitt605's Avatar
i agree with James4394, fuel pump
rodrigues
06-21-22 11:44 AM
Gustavo621
12-03-15 12:25 PM
edvinasj
03-30-15 04:02 PM
EroticA
08-27-08 09:33 PM
TTCUPS
Performance & Maintenance
03-02-05 02:48 PM
Quick Reply: Car won't start, help!
