IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Update On my IS300
Old 03-26-14, 08:43 AM
ArmyGrl88
ArmyGrl88's Avatar
Exclamation Update On my IS300
So I haven't updated in a while. Here's what is going on. As everyone knows I have replaced the following and then began getting multiple misfire codes:
1. Valve Cover Gasket
2. Spark Plugs and wires
3. All Ignition Coil Packs
4. Throttle Position Sensor
5. Cam Sensor
6. Crank Sensor
After sitting at my dealership for a week, they fixed the timing issue and had to replace another part. I can now drive the car but it idles to high, and they are suggesting the idle air control valve be replaced. I am out of funds at this point to pay for a new one. Suggestions?
Old 03-26-14, 11:02 PM
Chadley6mt
Chadley6mt's Avatar
is there any other shops in your area that you can consult with? (The dealer will charge you an arm and a leg for anything to be looked at)
do you have the actual codes that we can reference?
Old 03-26-14, 11:09 PM
1sWt2GS
1sWt2GS's Avatar
Take It to an Indy shop
Old 03-27-14, 10:37 PM
PIONEER
PIONEER's Avatar
did you remove the idle air control valve when you did the valve cover gasket? make sure you didn't put the baffle on backwards.
Old 03-28-14, 06:42 AM
ArmyGrl88
ArmyGrl88's Avatar
Default ...
No I didn't mess with that at all...
Old 03-28-14, 06:44 AM
ArmyGrl88
ArmyGrl88's Avatar
what??? umm im in nc
Old 03-28-14, 07:20 AM
Scratchy
Scratchy's Avatar
independent shop
71SoCal
RX - 1st Gen (1999-2003)
03-06-18 09:58 AM
Parson
07-05-17 08:49 PM
LScowboyLS
03-17-14 03:42 AM
SDIII
03-09-14 09:15 PM
Quick Reply: Update On my IS300
