Staggered Wheels
Staggered Wheels
New to the Club, looking for new ideas and suggestions on custom wheels for my 300. I've done a little research and have found 18"x 8"front 18"x 8.5"rear seems to be the starting point for Staggered Fitment. Can 17" Rims be found for Staggered set-up? What are some thoughts on lowering springs versus Adjustable Coil Overs?
Of course, 17's can be found, but I recommend 18's at least. 17's look way too small on the car. I run staggered with 18x8 in the front and 18x9 in the rear, offset is +40. Tires in the front are 225/40R18, rears are 255/35R18. I did a minor roll in the rear, not even close to rubbing. I recommend lowering with eibach pro kit springs with koni yellow struts, you don't need coilovers if this is a daily driver. been there, dont that many times. I guarantee you'll be satisfied with the strut and spring combo.
Good Info
Great, some solid information to start with, is the +40 offset for front and rear wheels? With the combination of new springs and shocks, what amount of the OEM smooth ride, will be sacrificed Thanks in advance
Lowlexus
09-10-10 01:52 PM
