IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
misfire problems on my 02 is300 BADLY HELP
Old 11-18-13, 09:04 AM
cura
cura's Avatar
Default misfire problems on my 02 is300 BADLY HELP
my car started stawling felt it misfire badly so went to change my spark plugs saw that it was full of oil so changed the head gaskets and it still misfire i checked the coil packs and they are all good checked the preassure on the cylinder heads and they are over 180psi now the changed the block control vaulve filter and 2 other things and it still misfire now the mechanic is getting a used computer for the car to see if its that does anyone know of might have an idea of what can it be
Old 11-18-13, 11:43 AM
cura
cura's Avatar
Changed the cranck shaft and cane shaft (something like that) and the temperature sensor
Old 11-18-13, 01:38 PM
MIS300
MIS300's Avatar
Just out of curiosity, how did you confirm the coils and wires were good? Any check engine lights?
Old 11-18-13, 03:23 PM
trivis300
trivis300's Avatar
probably your valve stems are going bad? Any chance of your valve cover gasket leaking?
Old 11-19-13, 08:53 AM
cura
cura's Avatar
Vailve cover gasket was changed once i changes the head gaskets it stopped leaking.... i check the coil pack with the car on just pulled it up and u feel it loose power check engine for misfire on #5
Old 11-20-13, 04:49 AM
is3wagon
is3wagon's Avatar
Did u change the plugs? If so, swap cyl#5 plug with any other plug and run it. Ive had new bad plugs. Delivery guy dropped them.Then swap coils if #5 comes up again. Then u can rule out coil &plug problem.
Old 11-30-13, 06:41 AM
is3wagon
is3wagon's Avatar
any luck yet?
JayCee1014
06-12-19 07:49 PM
GoCarSc300
Performance & Maintenance
03-12-15 09:08 PM
NihS07
08-30-11 06:52 AM
smoothie18
03-23-09 06:54 PM
DIYsquirre
10-15-06 01:44 PM
Quick Reply: misfire problems on my 02 is300 BADLY HELP
