IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Please Help Passenger Tail Lamp Doesn't Work
Old 06-26-13, 09:00 PM
bhagy002
bhagy002's Avatar
Default Please Help Passenger Tail Lamp Doesn't Work
So I bought my IS 300 yesterday knowing that there was a blinker out. I didn't realize the entire lamp was out. I checked the fuse in the drivers kick panel, and changed the the bulbs but the entire passenger tail lamp does not work. The driver side tail lamp and both trunk lid tail lamps (passenger and driver) work.
Where should I look next?
Thanks
Old 06-27-13, 08:46 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
time to start chasing wires - follow the wires from the assembly forward...
see where you stop having voltage... both positive and negative...
I'll look at the wiring diagram tomorrow to see where a junction block is that the wires meet up... being that none of them work, a ground would be most likely culprit...
BeansIS
SC400 / 300 Classifieds
11-21-11 08:32 AM
huNGjaii
08-28-10 10:41 PM
Xevuhtess7
09-07-05 10:20 PM
Quick Reply: Please Help Passenger Tail Lamp Doesn't Work
