Wheel question experts please help!! :)
So I want to buy some rims for my car but I know nothing about wheels and Fitment. Here is the info for the wheels I want to install.
My question is will this fit the car or what modifications must be done like camber kit, fender rolling, spacers Etc.
My only Current suspension modification is dropt on TEIN springs very thing else is stock.
Diameter: 18"
Front Width / Offset: 8" +35
Rear Width / Offset: 9" +40
2001 is300
Diameter: 18"
2001 is300
Hello 1Gis300,
I am not to sure how u want to run your set up; square to the road or with neg camber. I am http://my.is/forums/f89/using a formula from my.is and some info I gathered from there. Our front space from the brake hub to the outer limit of the fender (without mods) is 65mm and the rear space is 68mm. Having a drop does give you a bit more room but I am not to sure how much.
To figure out if your wheels with fit:
take width and divide by 2
8/2 = 4
9/2 = 4.5
Multiply by 25.4 to convert to mm
4 * 25.4 = 101.6mm
4.5 * 25.4 = 114.3mm
Subtract your offset from those values if your within the maximums they should fit
101.6 - 35 = 66.6
114.3 - 40 = 74.3
66.6 > 65
74.3 > 68
So looks like your going to have to roll the fronts and roll and pull the rears quite a bit.
8/2 = 4
9/2 = 4.5
4 * 25.4 = 101.6mm
101.6 - 35 = 66.6
114.3 - 40 = 74.3
66.6 > 65
74.3 > 68
lol
Wheels, Tires & Brakes Forum
06-25-13 05:43 AM
