LED lighting
LED lighting
Can anyone tell me how to install these? I'm not the best with electrical wiring. I just need to know where to connect.
https://www.clublexus.com/forums/att...1&d=1364931883
well it looks like there's a switch there so he wants to be able to turn it off and on, so run a cable to the battery with a fuse and connect it to the switch and run them to the leds and find a ground and make sure you sand off the paint.
Former Sponsor
From what the picture shows, its 3 pins:
Connect ground wires to the "GROUND" portion of the switch to metal or directly to the battery negative.
Connect live wires to the "SUPPLY/VOLTS" directly to the fuse box or battery, a constant power source.
Connect the LED strip wiring to the "ACC" pin in the middle, this should be the output for the switch.
igorxx
06-20-13 09:35 PM
CCJ22
08-08-12 05:32 AM
