IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
What Am I Missing??
Old 03-11-12, 11:45 PM
is300ok
is300ok's Avatar
Default What Am I Missing??
My car just hit 140k, what maintenance should i do? Spark plugs, timing belt, and water pump.
I wanna keep my car runny perfect. Please help! Thanks
Old 03-11-12, 11:59 PM
DLo_IS300
DLo_IS300's Avatar
FYI The timing belt, water pump, timing belt tensioner, and idler pulley maintenance was suppose to be done at 90k miles at the latest.
Old 03-12-12, 12:04 AM
is300ok
is300ok's Avatar
I'm not sure if it was, I bought the car with 93k on it. It runs perfect right now, I just wanna keep it that way and replace something before it actually messes up.
What is everything you suggest I replace?
Old 03-12-12, 06:40 PM
ais300c
ais300c's Avatar
fluid flushes, i.e. trans coolant brake u should be good wit that
Old 04-15-12, 09:43 PM
Stopitnow
Stopitnow's Avatar
intake cam o-ring, rear end service, inspect carrier bearing and driveshaft for excessive play, caliper slide pins, inspect balljoints, tie rod ends, sway bay end links front and rear, sway bar bushings front and rear.
joe42276
10-23-10 07:07 PM
LexusPhan
08-21-09 05:45 PM
Two bit
01-02-08 08:26 AM
dfish
RX - 1st Gen (1999-2003)
12-20-07 01:34 PM
Och
05-15-06 08:01 PM
Quick Reply: What Am I Missing??
