IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
One for the BOOKS. (Problem)
Old 08-11-11, 08:54 AM
03is300ztk
03is300ztk's Avatar
Originally Posted by Justin727
Have you bought the test kit from NAPA yet? It's not expensive and will give you more of a clear answer then what you have already.
Try to get it done today my friend and let us know the results. Pick up a rad cap and thermostat too while you're there as they aren't expensive either.
Headed there now, gonna grab the kit but not sure about the thermostat because it has not overheated once yet so gonna see what happens with this test.
Old 08-11-11, 09:07 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Originally Posted by 03is300ztk
How do i check this, when i had the cap off i pushed on the retainer spring and it felt like it had good pressure???
the same kit used to pressure test the cooling system should have an adapter to pressure test the cap...
I have done the same "test" and them still be bad / leak...
Old 08-11-11, 12:29 PM
Justin727
Justin727's Avatar
Can't wait to see the results. Hopefully good results
Old 08-11-11, 01:04 PM
03is300ztk
03is300ztk's Avatar
Well block test turned out well, no color change at all!!!!
Also replaced the rad cap just to be safe. Ran the car at idle for about 20 mins playing with the throttle methodically giving some high revs to get the temps up, with no A/C running the fans are kicking on as they should. So im stumped but happy.
Old 08-11-11, 01:05 PM
03is300ztk
03is300ztk's Avatar
The kit i got from autozone doesnt have any adapter for the rad cap, so i just replaced it.
Old 08-11-11, 01:59 PM
Justin727
Justin727's Avatar
Good glad to see the results. Just keep an eye out on everything and let's see if it happens again..
Old 08-11-11, 10:04 PM
llllllllll
llllllllll's Avatar
Very strange.. Car voodoo!!
You should trade it in, just don't let the dealership know about any issues!!
Old 08-12-11, 07:36 AM
mitsuguy
mitsuguy's Avatar
that can kinda come back on you... I know a guy who had a lower end rod knock in a Corvette, had a performance shop replace just that rod's bearing which cured the knock and he traded it in... after the car sold from the dealership, the new owner put about 300 miles on it before it started knocking again... long story short, the original owner paid to put a new motor in the car...
Itallgood
Suspension and Brakes
09-11-18 10:55 PM
HOLGER21
12-21-12 07:51 PM
kmy
10-31-12 04:54 PM
Do.Man
05-10-09 10:22 PM
Quick Reply: One for the BOOKS. (Problem)
