IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
works RIM sizing help please
Old 07-06-11, 10:20 AM
madmaxoo7
madmaxoo7's Avatar
Default works RIM sizing help please
i would like to get some help in sizing rims for my is300 please, i am buying a set of works vs-xx 17x8 +47 and 17x9 +47 i would like to know whether they will fit on the car clearing the brake caliper and not hit the inner fender. would it fit without any modifitcation?
Old 07-06-11, 10:42 AM
sway162
sway162's Avatar
Those will fit fine. Are you on stock suspension? You may rub a lil bit on the rears....but if you are lowered at all you should be just fine.
Old 07-06-11, 09:28 PM
WhiteAngel
WhiteAngel's Avatar
It will sit perfectly fine front and back, even if you slam. i run 18x9 & 18x10, also slammed with pulling fenders in the front, back running neg 4 camber. it sits perfectly fine. so with your sizing, i think there wouldn't be a problem.
Old 07-06-11, 10:21 PM
llllllllll
llllllllll's Avatar
Can you ask your dealer if they will sell center disks?
(my local rep won't, what's the point of getting 3 piece wheels if you can't get replacement centers.. wtf...)
I need two 19" centers - VS-XX (R) disk - gold.
If they will sell the centers, I will give you my contact info.
Old 07-06-11, 10:25 PM
llllllllll
llllllllll's Avatar
Just to let you know.
VS-XX with too much offset isn't that nice looking.
These are +43
http://minneapolis.craigslist.org/ra...426086873.html
Here are my VS-xx with +21 offset, sometimes I wish I had even less!
Old 07-07-11, 05:45 AM
baadhabit
baadhabit's Avatar
talk to Rav Spec who are work wheel dealer and forum vendor or call another dealer
http://www.workwheelsusa.com/dealers.php
Old 07-07-11, 05:47 AM
baadhabit
baadhabit's Avatar
you can pull, chop and camber to make anything fit. how is that even relevant. useless post of the day
Old 07-07-11, 05:59 AM
baadhabit
baadhabit's Avatar
those should fit fine. 225 tire up front possibly 245 tire in the rear
a quick fyi, whether a rim clears a brake caliper depends on the spoke design not necessary offset and size. for stock brakes i would talk to the dealer possibly run the standard Adisk up front and the deep rim ODisk in the rear. any big brake would require a higher disk type
if youre open to other size options another easy set up could be 18x8 and 18x9 +38 offset. step up the rim size and the lower offset help bring the rim a little further out closer to the fender.
Old 07-07-11, 07:37 AM
rvalero
rvalero's Avatar
You might have issues with the front wheels rubbing against one of the suspension arms. I know that the 2IS 17" wheels needed a spacer to clear. IIRC, the specs are 17x8+45. Due to the larger diameter, the 18" 2IS wheels fit with no spacers required. The rear wheels (17 or 18) didn't have issues.
Old 07-07-11, 09:41 AM
llllllllll
llllllllll's Avatar
Thanks, messaging him now
Old 07-07-11, 07:23 PM
madmaxoo7
madmaxoo7's Avatar
any one have pictures showing the details i would greatly appreciate it , its a used set i am getting for $1100, i would love to get a set of 18's in these, wish i knew someone selling a set which is not damaged, thats clears the fenders and stock brakes
Old 07-07-11, 11:41 PM
rvalero
rvalero's Avatar
I found some pics of the same wheels w/ the same specs. I don't know if the owner needed spacers up front, but here are a couple of his pics.
From kraven9's FS thread: http://my.is/forums/f99/fs-17-work-v...00-nyc-416077/
Old 07-08-11, 01:19 AM
llllllllll
llllllllll's Avatar
^^ nice honda... i mean, lexus
Old 07-08-11, 04:36 AM
kraven9
kraven9's Avatar
^^Thanks... you're funny.
Yes Rey I was running the same size and offset with 225/40 up front and 245/40 no spacers. My rear fenders are rolled.
Old 07-08-11, 06:37 AM
baadhabit
baadhabit's Avatar
oh yeah that blue. mh i dont know what you were thinking.
Quick Reply: works RIM sizing help please
