IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
so mpg any 1
Old 07-04-11, 09:40 AM
whymyis
whymyis's Avatar
Default so mpg any 1
My car is bonestock and i love it. Now im looking to improve mpg just a little and start with suspension. I am ordering coilovers tonight and wheel studs so I can put the back out just a little. My ? is on the wheel studs what size should i get to add 5mm spacers in the back. And what u guy's been doing to gain another mpg on gas maybe?
Old 07-04-11, 10:15 AM
rvalero
rvalero's Avatar
If you get H&R or Ichiba spacers, they will come with the proper wheel studs. I would probably swap them out myself, but I've read that extended studs aren't necessary for 5mm spacers.
Old 07-04-11, 02:51 PM
ARehman
ARehman's Avatar
My car gets ****ty gas mileage, I just live with it. Drive it like a grandma to improve your mpg. But you'll prob be averaging around 20-22 mpg which is what I get and I'm fine with that.
Old 07-04-11, 06:02 PM
nsh1351
nsh1351's Avatar
Drive like a grandma as stated, try to take the highway as often as you can, and I noticed my srt intake helped when I'm not mashing the gas.
Old 07-04-11, 09:19 PM
dsp979
dsp979's Avatar
Spacers won't help with gas mileage.
No need for extended studs with just 5 mm spacers. Someone said it was safe up to 7 mm spacers.
10 mm spacers, you should use extended studs.
As for mpg, tune up the car, bump tire pressure to 35-36 psi, get an alignment.
I got about 230 miles on half tank of gas driving around 70-75 mph, 95% of it freeway, last Saturday night.
Old 07-04-11, 09:26 PM
thainsane
thainsane's Avatar
If I drive my is350 like a granny I get 32 mpgs. If I drive my isf like a granny I get 28 mpg..... but I cant drive like that so my 350 gets around 22 and my f gets between 13 to 15. Mpg isn't always what you drive its how you drive.
Maher331
07-03-17 02:15 PM
Blueshark
ES - 5th Gen (2007-2012)
04-25-15 05:18 PM
DougJoseph
12-10-12 12:04 PM
LilMan23
02-09-11 02:28 PM
jnguyen87
10-15-09 02:01 PM
Quick Reply: so mpg any 1
