IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Need boost - opinions?
Old 05-29-11, 08:33 AM
IS3003o3
IS3003o3's Avatar
Default Need boost - opinions?
Hey guys. Just recently inherited my sister's 04 IS300 for my 2nd DD.
First off it's over 100k (not sure exact #), hasn't been properly maintained (oil changes, services, etc) for some time, and been in a few accidents (needs body work). I figured it'd be my new project and planning on boosting it. Question is - should I do anything w/ the engine (rebuilt, cleaned, etc) or should i just bolt on a kit and call it a day?
Joe
Old 05-29-11, 06:25 PM
baadhabit
baadhabit's Avatar
do the maintenance
Old 06-03-11, 02:50 AM
llllllllll
llllllllll's Avatar
That is a fire idea! Strap on a turbo and call it a day!
Old 06-05-11, 09:48 AM
IS3003o3
IS3003o3's Avatar
haha thx guys
Old 06-05-11, 11:30 AM
slidingIS
slidingIS's Avatar
Fire idea lolz!
I agree with lllllll throw on a kit and go til it blows
Old 06-05-11, 11:31 AM
slidingIS
slidingIS's Avatar
Oh change the oil and leave it beat up too haha
Old 06-05-11, 12:00 PM
rayy117
rayy117's Avatar
hahaha sleeper if its all beat up and turbo
Old 06-05-11, 04:47 PM
llllllllll
llllllllll's Avatar
thats the fire!!
Old 06-07-11, 01:41 PM
IS3003o3
IS3003o3's Avatar
what's the average cost to rebuild?
Old 06-07-11, 01:43 PM
Justin727
Justin727's Avatar
There is no cost currently... No need to rebuild if you're throwing a turbo kit on it at the moment!! I've got that fire!
Old 06-08-11, 07:20 AM
slidingIS
slidingIS's Avatar
Theres no average. Its just how much you are willing to spend and how well you want it to run. best route is 2jzgte swap for reliability and cost.
Old 06-08-11, 12:50 PM
llllllllll
llllllllll's Avatar
Theres no average. Its just how much you are willing to spend and how well you want it to run. best route is 2jzgte swap for reliability and cost AND FIRE!!
fixed ^^
Old 06-08-11, 02:45 PM
madchyers
madchyers's Avatar
For a proper rebuild you're looking at a lot of cheese.
If you're not taking it apart yourself, you're gonna be paying a shop a lot of money to take the block apart down to a bare block. Then you'll need every port remachined - bored, honed, etc.
Then you'll need new internals, don't use internals 100K old that haven't had the greatest maintenance. You're looking at rods, bearings, pistons, rings, re-balanced crank, main seals and bearings, an entire gasket kit, head gasket, waterpump, timing belt, oil pump...Then headwork, you may be able to reuse the valves, springs, retainers and all that ish.
Then you'll need your basic fluids, oil, coolant, etc...
And I know there are other things here and there that I missed. Once this is all done, you'll need to either buy a turbo kit or piece on together, then once that's installed, tuning will come into play. But before you throw on a kit and start boosting, you'll probably want to break in the motor N/A for a thousand or so miles before it starts taking another beating.
Old 06-08-11, 03:34 PM
Justin727
Justin727's Avatar
Best advice I've seen! I advocate this not just with n/a cars but also with boosted cars as well. I broke my Supra in bone stock(turbo). After 3k miles I took all the stock stuff off and put on the big stuff!
Old 06-09-11, 06:55 AM
baadhabit
baadhabit's Avatar
what do you mean by rebuild? what are you rebuilding?
the car is at 100k miles. it should be fine for at least another 100k even under boost, if you do the maintenance.
Quick Reply: Need boost - opinions?
