IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Need help restoring my headlights on is300
Old 05-04-11, 12:34 PM
TYPEONE8
TYPEONE8's Avatar
Default Need help restoring my headlights on is300
Hi im going to restore my headlights myself so need some help on what kind of materials i need. The driver side is pretty bad but the other headlight you can see through it but it has a little build up, so do i need to do the same to both headlights even though ones not as bad as the other. Please list materials that i would need. Thanks for the help.
Old 05-04-11, 12:49 PM
IS-Sk8nerd
IS-Sk8nerd's Avatar
Waterhose
Wet Sand paper
That polish kit they sell at the majority auto parts store with in the car wash section
Time
Elbow grease
Yes do both it will save you work later on.
You might want to swarch for a thread on here I know people have posted the process up.
Old 05-04-11, 12:51 PM
baadhabit
baadhabit's Avatar
for a novice person i would suggest a kit like one Meguiars sells.
http://www.meguiars.com/video/index....d%20Headlights
Old 05-04-11, 01:10 PM
baadhabit
baadhabit's Avatar
i'd also suggest, once you have it clean you install a clear film like 3m to prevent the haze from coming back. there is only so many times you can sand the lens down before it starts to crack
http://www.lamin-x.com/Lexus-IS-2001-to-2005-s/479.htm
Old 05-04-11, 01:33 PM
TYPEONE8
TYPEONE8's Avatar
on that 3m film is it cut to fit or is it already pre cut to the lense. what about the 3m restoring kit?
Old 05-04-11, 04:23 PM
UNOHOO
UNOHOO's Avatar
i tried the 3m restoration kit, they came out worse and i had scratches around the lights and a lot wasted time to show for it...i used plast-x and it helped a lot, not perfect but a whole lot cheaper than new, whole lot faster and better than the 3m BS
Old 05-04-11, 04:24 PM
UNOHOO
UNOHOO's Avatar
LOL someone shouldve taped me, i bet i looked like those people on infomercials that make everything seem so hard lol
Old 05-05-11, 01:49 AM
TYPEONE8
TYPEONE8's Avatar
I bought the turtle wax restoring kit just want to know if anybody has used it cause if it doesn't work then ill return it and get 1000,1500,2000 sandpaper and wet sand it and ill also buy PLASTX solution let me know thanks
Old 05-05-11, 06:42 AM
baadhabit
baadhabit's Avatar
Originally Posted by TYPEONE8
on that 3m film is it cut to fit or is it already pre cut to the lense. ...........
did you follow the link i posted?
Old 05-05-11, 10:42 AM
TYPEONE8
TYPEONE8's Avatar
yeah its said something about server down ima try it again today. I think ive been on there website dont they make cut to fit also different colors of film.
Old 05-05-11, 10:48 AM
baadhabit
baadhabit's Avatar
here ya go
Buy precut covers or custom apply Lamin-x with Universal Sheets or Rolls
Old 05-05-11, 02:19 PM
TYPEONE8
TYPEONE8's Avatar
ok so i just got done using the turtle wax restoring kit, my passenger side headlight wasn't as bad as the driver side so all i did was apply the lens clarifying compond rubbed it in then wiped it off and it cleaned it up really nice, the driverside was a different story i used everything included and did the process twice and it looks like crap, and i also seen that its from the inside also. The company says i can use a drill and a foam pad and use there clarifying compound, so would that work to take the scratches off the outside or do i need to go with a different sandpaper, and also how do i take the headlight apart to clean the inside. I forgot to take before pictures but i have the after pictures. Need help restoring my headlights on is300-1304623914612.jpg
Old 05-05-11, 04:22 PM
TYPEONE8
TYPEONE8's Avatar
Why i also think its inside is because when you look at the driver side theres a black spot i think who ever had this car painted the inside lense or something and they didnt seal it right and it got that yellow hazing inside the lense heres a picture.
Old 05-06-11, 08:25 AM
baadhabit
baadhabit's Avatar
open the hood and check the seems of the lights to see if its been opened. you should be able to tell
i hear the inside of the OEM lights have this special frost that if its cleaned out will ruin the lights.
Old 05-06-11, 08:31 AM
baadhabit
baadhabit's Avatar
if you want to try sanding follow the vid i posted. sand paper you should be able to pick up from any auto parts store.
Quick Reply: Need help restoring my headlights on is300
