will someone confirm my results?
1 Post
ok so im currently running 19x 8.5 with +43 offset, stock wheels are 17x 7 with +50 offset, i found a place to widen the stock wheels for me, so if im going to do that and make them 8.5 it will make the offset approx +66-67 mm, which if i use a 25 mm spacer it should put the wheel in about the same place in relation to the fender (not the hub)
did i do this right? (when they make the stock wheel wider they will be cutting off the back lip and adding a wider end to it to achieve desired width)
second question, im currently running a 10 mm spacer on the rear with the 19's mentioned above. ichiba does not sell a 35 mm spacer, could i keep my current spacer on and add a second spacer (type 2 from ichiba) and not be at risk? current spacer is type 1, here are link to both
10 mm type 1 spacer (currently on car)
http://www.ichibausa.com/10alwhsp5.html
25 mm type 2 spacer
http://www.ichibausa.com/25albowhsp10.html
25 mm type 2 spacer
