IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Just started my swap!
Old 04-20-11, 05:55 PM
  #61
cashed350
cashed350's Avatar
Originally Posted by baadhabit
what kind of tests did you do on the motor when you picked it up? compression?
None. I trust the company that I buy from. Especiallynow that they are going to warranty it for me. I am however going to put a mechanical oil pressure gauge on it for when I start it this time to make sure it has the proper oil pressure so there is no guessing!
Old 04-21-11, 05:36 AM
  #62
ItsBreezy
ItsBreezy's Avatar
Good luck, I should be starting a swap in a couple months!
Old 04-21-11, 08:00 AM
  #63
IS300TURBO
IS300TURBO's Avatar
She ran good...when she ran. Lol
Old 04-21-11, 08:45 AM
  #64
llllllllll
llllllllll's Avatar
How much does an engine cost?
And how much would you charge to install in my IS300?
Or if i get a supra how much would you charge to put in a GTE?
Old 04-21-11, 09:02 AM
  #65
baadhabit
baadhabit's Avatar
a GTE motor generally runs about 2-3k. the labor could be about the same 2-3k. thats just a stock motor. no upgrades.
in a Supra you will probably save a little on the labor because its plug and play ecu
Old 04-21-11, 08:32 PM
  #66
cashed350
cashed350's Avatar
Yes labor would start at $2k and go up from there depending on what all you wanted to do, and as far as in a supra, yes it would be less. Remember the supra wouldn't be vvti so the motor set would be more like 1800-2200 depending.
Old 04-23-11, 07:09 PM
  #67
sugzz
sugzz's Avatar
Sorry about the mishap with the motor. Good luck...
Old 04-24-11, 10:03 AM
  #68
cashed350
cashed350's Avatar
new motor looks better than the last. the letters on the coil cover are still chrome and noone has tried to repaint it either! head is bright aluninum and no grease stains what so ever, of course that didnt prevent me from cleaning and pressure washing anyway, lol. i will post pics later of the things i will be re-doing, brake lines, ect; and reinstalling to be running by this friday. Both my cars have been selected to be posted up with a few others in front of our RAVE Cinema for the opening of FAST FIVE, i know that may seem a little lame, but since this IS didnt make it to Import Alliance last weekend, this is a small WIN for me.
Old 04-24-11, 08:29 PM
  #69
slidingIS
slidingIS's Avatar
^haha nice!
Old 05-06-11, 05:54 AM
  #70
cashed350
cashed350's Avatar
will post pics soon, not alot been goin on. had a few things fabbed up, been learning from the first install and moved some things around and seeing as i no longer have any kind of deadline I have been taking my time and doing things a different way. Had the rear turbo pipe milled as suggested, also the pipe with the valve in it cut out (again) and have been rewiring my WB02. Also studying the pros/cons of removing the wastegates or which ones to remove/wire open.
Old 05-12-11, 03:19 AM
  #71
cashed350
cashed350's Avatar
New motor is back in and was still a PiTA! New ps lines ran, new gauge wires well hidden, almost running again. Startup should come later today ( with video) and then I will be having new IC piping made for that "perfect fit!" If I have enough interest and people like what they see I have the ability to have these produced and can offer at a decent price!
Old 05-12-11, 08:02 AM
  #72
Justin727
Justin727's Avatar
Hit me up when you start producing parts good sir
Old 05-14-11, 10:10 AM
  #73
cashed350
cashed350's Avatar
Well she's alive (again) and very healthy, 80psi oil pressure at startup and high idle, 90+ for rev up, and 30+ @800 rpm @ idle. Thank god! 14lbs and only a CEL for the final 2 o2's that i haven't sim'd yet, looking up diagrams now for that fix. pics will be up later today. I want to finish painting all my trim pieces today and try to fit the bumper and greddy lip today.
Old 05-14-11, 06:46 PM
  #74
Justin727
Justin727's Avatar
PICS!!! Where are they?
Old 05-15-11, 02:49 PM
  #75
cashed350
cashed350's Avatar
pics up!!!!
Attached Thumbnails Just started my swap!-swappics-004.jpg   Just started my swap!-swappics-016.jpg   Just started my swap!-swappics-013.jpg
Quick Reply: Just started my swap!
