IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Why does my IS consume so much GAS?
Old 02-11-11, 01:10 PM
sway162
sway162's Avatar
Try Seafoam and clean your MAF sensor
Old 02-11-11, 02:02 PM
skinfan2k
skinfan2k's Avatar
i get about 350-370 per tank. how are you guys getting such a low mpg
Old 02-11-11, 02:28 PM
smajroh1
smajroh1's Avatar
What is Seafoam?
Old 02-11-11, 02:32 PM
smajroh1
smajroh1's Avatar
Also where could I find a JoeZ intake cause I havent heard of them?
Old 02-11-11, 02:36 PM
Justin727
Justin727's Avatar
http://www.l-tunedparts.com/product/?id=2853
Old 02-11-11, 03:00 PM
sway162
sway162's Avatar
Originally Posted by smajroh1
What is Seafoam?
http://executiveautosociety.com/foru...hp/214-SeaFoam
http://my.is/forums/f88/seafoam-engine-cleaner-260257/
Old 02-14-11, 08:47 AM
smajroh1
smajroh1's Avatar
Thanks for the info Sway. I am going to invest in seafoam for sure!
Old 02-15-11, 12:39 AM
dsp979
dsp979's Avatar
Originally Posted by DaveGS4
Set appropriate tire pressure as defined on door jamb or owners manual
Get a general tune up including new spark plugs
Drive more conservatively (avoid jackrabbit starts)
Log your actual MPG for a while when you make these changes, rather than miles per tank.
+1
My tires are actually set at 35 psi.
I would like to add, get an alignment, especially if it hasn't been done in a while.
Make sure to read the pros and cons of Seafoam. I'm wary of using the stuff, despite what people claim.
Old 02-15-11, 07:56 AM
embolism
embolism's Avatar
I'm wary too. As long as you always put in 91 octane, and change your oil regularly you should be fine. There are some pics of engines opened up for the valve tsb and those babies were spotless inside. This was after 3 or 4 years too!
Old 02-15-11, 11:09 AM
SofaKingAZ
SofaKingAZ's Avatar
I've had my '02 IS 300 since Dec. 01 and I've always gotten 19-21 mpg.
Old 02-16-11, 09:59 AM
Vic Nyce
Vic Nyce's Avatar
i have yet to put a whole tank through my car but so far i've clocked 240 miles and am just below the half mark on the gauge. too bad the bottom half of the gauge drops so fast compared to the top half.
i've read that this car got similar mileage to my old GS400 so this is a pleasant surprise. i couldnt get 240 miles per tank downhill with a tailwind on that bad boy.
my IS is a 2003, manual, header back exhaust, with 2 codes on the CEL - P01420 and P01430. hopefully the mileage remains as good or improves once I iron out the CEL triggers.
Old 02-16-11, 10:04 AM
apMango
apMango's Avatar
seafoam is the shEEt
durps
SC- 1st Gen (1992-2000)
13
11-05-12 04:03 AM
LEXXXIS
11-15-10 08:10 PM
lx470man
IS F (2008-2014)
28
10-12-09 12:43 PM
PureDrifter
72
02-24-09 07:07 PM
lexus123
ES - 5th Gen (2007-2012)
08-18-06 08:25 PM
Quick Reply: Why does my IS consume so much GAS?
