unknown problem(s) with my IS300. (Searched and no answers)
Cleaning and reinstalling the ABS sensor isnt always the fix. Sometimes you actually have a bad sensor and have to replace it. Had that happen on a Corvette I used to have and it had similar issues where i was told to clean and replace wheel speed sensoors and I ended up having to buy two new ones.
Also follow the wiring coming off the wheel speed sensors. sometimes one of those wires gets frayed or broken and shorts out.
ECU could be bad as well. or theres a wiring issue(which i hope isnt the problem)
any suggestions?
and BTW, this might help, but previously i had an incident of blowing my main fuse due to hooking up a battery the wrong way I replaced the fuse and everything was fine. the issues did not occur until almost a year later.
Even tho, it took a yr for the problem occurred. You probably fried something, and it eventually broke
i tried. brought it to lexus of las vegas, they charged me $65 to tell me that my computer plug is not reading. then they want $250 to diagnose whats wrong with my car. not trying to be cheap, but i rather spend some extra time trying to figure it out myself then spend $250 just for them to tell me what's wrong with my car.
Dude i feel for you, but in all honesty something like that is meant for the pros ( I work in a shop and believe me its the best way sometimes) its hard when diag comes into the picture but I would find like an outside place that deals only in toyota like where im at in fl i have the toy house that if I dont know I take it there they are awesome ( I know it sounds like a sex shop lol )
but u say it happens after u hit bumps. car been in any sort of accident? or u got pack rats? they can chew on the wiring and cause lots of funny stuff. in the end id pay the 250 and that way whatever they find wrong and fix it will be under warranty through toyota.
ya whenever you cant connect with the obd2 plug usually means ecu problems. im a tech at toyota and that happens there are so many tests we have to do to figure out whats goin on and why. if your ac stops blowing id say hit ur blower motor and it will prob start working again but you say it only happens when ur trac light is on then im not sure. id deff start with that obd2 connector, once you got that then being able to look at data lists will be way helpful towards ur other concerns.
ON POINT. i also forgot to mention that i got into a minor wreck. i hit a BIG rock (usually placed in people's front yards as a decor) the result was a cracked front bumper and a bent chassis. the chassis was pulled straight by a professional body shop, and then after another body shop did the paint. and while they did the paint, they pressure washed my engine bay and accidentally got water in my engine (coil pack, spark plugs were wet)... this all happened within a year i believe. one of the worst year my lexus has ever gone through.
During my research I found out that the best way to figure out if i have a bad wheel speed sensor is to perform a continuity test. That's something Im not familiar with and do not have the proper tools. I got a quote from a local shop and was told that its a very timely task..
any suggestions?
any suggestions?
Sounds like an expensive mistake on the battery cables.
I would spend the money to get it fixed threw lexus. Get a credit card, if you dont have the cash.
Good luck with your issue. Hopefully it works out in the end
