IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Throttle Problems ??
Old 09-21-10, 06:12 PM
ISash300
ISash300's Avatar
Default Throttle Problems ??
Does anyone have a problem with thier IS300 not reacting right away to full throtle and feeling sluggish and then acclerates more at the top end ?
I Read somewhere about the is300 throtle only opening up 50%...??
Anyone else have a problem with this or have any idea whats up with it?
Old 09-21-10, 07:32 PM
03LexIS300
03LexIS300's Avatar
its a common problem on most all is300's, as you said the throttle only opens up 50%, i think there are ways to make it open up 100% as people have done it before i believe, also some sort of problem in the ecu that is known to cause this. i think you can upgrade your ecu, but if i'm not mistaken ive heard people say it still doesn't help much.
Old 09-21-10, 08:37 PM
FMLis300
FMLis300's Avatar
I just accept the fact that it's not a sports car.
Old 09-21-10, 08:57 PM
voleduy
voleduy's Avatar
But its not a sedan car either. There are no sedan cars at that time contain the I6 engine swapped from Supra. Actually it is a sport car in someway.
For the question, so I dont even know the throtle just open haft.. how do we know it?
Old 09-21-10, 09:10 PM
03LexIS300
03LexIS300's Avatar
haha well it not a porsche 911 turbo, but it isn't a checy chevette, lol so its in between, not by any means really sporty, but it's sporty
Old 09-22-10, 06:26 AM
baadhabit
baadhabit's Avatar
try tightening the throttle cable a little. maybe its just loose.
another option is adding a spacer under the gas pedal
https://www.clublexus.com/forums/is-...ottle-mod.html
Old 09-22-10, 06:27 AM
baadhabit
baadhabit's Avatar
what are you talking about
Old 09-22-10, 09:07 AM
ISash300
ISash300's Avatar
Thanks for the help ...
Even tho its not tech. a sports car it shouldnt have such a delayed reaction when accelerating... I researched the reason and the only answer i came up with was the only 50% open... but Im hoping to find a way to fix it..
How would a spacer help?? Kind makes no sense to me to use a spacer...?
Old 09-22-10, 10:31 AM
03LexIS300
03LexIS300's Avatar
if you put a spacer under the gas pedal and adjust the cable to idle right when that spacer is under there, and take the slack off the cable. there should be more distance between the pedal and the floor allowing the throttle to open up more when pushed from where it is normally with the spacer all the way to the floor.
Old 09-22-10, 11:18 AM
baadhabit
baadhabit's Avatar
do you actually have a problem or only "heard" there is a problem?
Old 09-22-10, 01:54 PM
sway162
sway162's Avatar
This^ Tighten the throttle cable all the way. Your throttle should be nice and touchy after this.
You can port your throttle body as well. Also the little things....clean your throttle body and MAF sensor. Spark plugs....when was the last time this was changed?
Old 09-22-10, 02:28 PM
ISash300
ISash300's Avatar
I can tell right away that it is not working right ..
Lets say this...
I push on the gas pedal and then the car does not move ...
The car gets closer to redline and engine revs but the car doesnt move until close to redline....
Car was serviced and checked out b4 I bought it...
Old 09-22-10, 02:29 PM
ISash300
ISash300's Avatar
I will take a look again and tighten up the cable and see if that helps any.... thanks
Old 09-22-10, 09:02 PM
03LexIS300
03LexIS300's Avatar
try the throttle cable and MAF, doesn't sound like throttle cable but try it and see. Sounds more like MAF. When they get really dirty or go bad it can cause very bad hesitations in acceleration and make the car seem sluggish and non-responsive, you can remove it and use some MAF cleaner they sell at the parts store and try cleaning it and reinstalling it and see if that helps.
Old 09-24-10, 07:55 AM
baadhabit
baadhabit's Avatar
Lets say this...
thats a different story than what you started the thread with. sounds like your car has other issues besides the throttle body.
have a mechanic pull the codes and check the maf sensor
Quick Reply: Throttle Problems ??
