IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
My 02 Lexus Is300 RPM is high at 65mph
Old 03-01-10, 05:24 PM
hlu1
hlu1's Avatar
Default My 02 Lexus Is300 RPM is high at 65mph
Hello,
I am new to this forums. I just bought a 2002 Lexus IS300 Automatic a month ago. I notice my RPM is quite high at certain speed.
At 65mph my RPM is 2600-2900
At 70mph - 80mph its at above 3000 RPM.
Is this normal?
I also have one more problem, When I brake at high speed, let say im going 70mph, my steering wheel would shake while I'm braking. What's the source of the problem?
Please help me out!
Old 03-01-10, 05:27 PM
jadu
live.love.laugh.lexus
jadu's Avatar
rpm's look normal.
Old 03-01-10, 05:51 PM
BernieIS
BernieIS's Avatar
Originally Posted by hlu1
Hello,
Is this normal?
Please help me out!
First, welcome to the forums.
the rpms seem right on
The shudder seems to be warped rotors which is an easy fix.
Old 03-01-10, 10:00 PM
hlu1
hlu1's Avatar
Thanks,
I used to drive a honda accord 4cyc. The rpm is a huge difference. Wasn't really used to it. Since everyone say its normal, I guess I could rest assure.
And about the rotors, if its left untreated, is it dangerous to drive?
Old 03-02-10, 05:52 AM
BernieIS
BernieIS's Avatar
It is not really dangerous but it will cause the pads to wear out faster. This is a really easy fix. You should be able to do this yourself with basic hand tools.
Here is a DIY from my.is
http://my.is/forums/f89/brake-pad-ro...tached-255699/
Old 03-02-10, 06:48 PM
LexusGSXR
LexusGSXR's Avatar
this is how these cars intend to be a gas guzzler, its from the high RPMS ride..
Old 03-02-10, 10:51 PM
tailwind4
tailwind4's Avatar
yeah i came from a honda prelude 5spd and when i first drove mine i thought the same thing but its just how these things run
Old 03-07-10, 12:44 PM
Lazy
Lazy's Avatar
yup rpm looks fine. Change ur rotors and pads. just 2x 17's and 1x 14' u need to take out after the wheel. Did mines yesterday and it took about 20-30 minutes.
Old 03-17-10, 09:40 PM
hlu1
hlu1's Avatar
I finally Change the rotors and pad. Now there is no vibration slowing at 60-70mph. Thanks guys!
When I removed it, It turn out the previous owner have aftermarket pads one side, and OEM on the other. One side is not even and it has less than 1/4 life on the pads. Thank god I check on those. And the aftermarket, it has a lot of life but its uneven. Both rotors are pretty banged up.
love my is!
Old 03-11-14, 08:37 PM
51auto
51auto's Avatar
Default Lexus RPM 2300
Your Lexus IS300 should be at 2200-2300 RPM's at 70 mph. Your car isn't shifting into 5th (OD) gear. You can make the adjustment by adjusting the cable on the throttle body. What usually happens, is the throttle body is removed to replace the spark plugs and when the throttle body is reinstalled they tighten the cable (nut) on the wrong side, being there is two nuts, one on each side of the cable bracket. Note: The right way to adjust it: have someone push gas pedal to the floor (with the car off) check to see if the cable is opening the lever all the way, if not or if it 's bottoming out make necessary adjustments and tighten nuts and when you release the gas pedal your cable should be set in the correct position. Basically the leaver should be all the way opened when the gas peddle is all the way to the floor.
Old 03-12-14, 09:38 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
51auto, unfortunately, your numbers are flawed.
Auto IS300's are a650e transmissions.
4th gear is a 1:1 ratio, 5th gear is .753:1
Rear diff ratio is .392
With a 215/45-17 Tire (OEM), 24.6" diameter, Vehicle speed at 3000 rpm in 4th gear would be 56 mph, and 5th gear would be 74 mph. At the 2200 rpm you quoted, you would only be going 41 in 4th and 55 mph in 5th...
Old 03-14-14, 04:48 PM
mmartin061
banned
mmartin061's Avatar
Ya all auto IS300's run high rpms. I remember having a '94 Tbird with the new 4.6. At 70 I think it was at like 1900 Rpm and also got 29 mpg on freeway driving between 60-80 for 200 miles before reformulated gas. Ahh the good ole days.
Old 06-13-21, 02:15 PM
BriBri86
BriBri86's Avatar
Default My Lexus is running 3000rpms at 70
Hello,
Is this normal?
Please help me out!
Did you figure this out
Old 06-22-21, 12:37 PM
1997Soarer
1997Soarer's Avatar
It was answered.
All auto IS300s run higher RPM on the highway. That's just normal for these cars.
The shudder while braking is either warped rotors or wheel bearings. If you put new rotors on and the car is still shuddering, it's 100% wheel bearings at that point
jasonsluck
07-02-14 02:17 AM
dyldough
Performance
20
09-15-12 07:12 PM
azari
18
05-16-10 03:59 PM
VIPJOSH
65
07-13-09 05:59 PM
kokonutjc
25
01-25-04 07:41 PM
Quick Reply: My 02 Lexus Is300 RPM is high at 65mph
