Navtool installation on IS300....I'm stuck
Has anyone done a diy installation with the navtool and factory nav system on IS300? I just bought the navtool kit and began installing the navtool to the navigation computer and I'm stuck. I have the instructions but this is the first time I've done anything like this. If you guys know what I'm talking about I'm trying to install the accessory power wire with the ground cable. How am I suppose to do that? Instructions say I need to find the 18 pin black connector and find the gray wire. The next part says I need to ground the wire which is also on the 18 pin connector and is the solid white with a black line. I see the 18 pin connector and gray/white wire. What do I do now? As you guys can tell, I'm a noob around here so any information is appreciated! Thanks
