need some help guys
need some help guys
ok so i bought my is300 the other day and i found out its lowered on h and r springs. the dumbass said he done it right, but when i went to change my oil a little bit ago i got to looking and the tires are chewed on the inside. the fronts have wires showing. the back are a tad worn on the inside but not so bad. i need a camber kit so any suggestions on where and what brand to get?? im in need of this bad so any help would be great. thanks!!
http://my.is/forums/f89/camber-kit-g...ry-56k-276682/
read those 3 pages.
summery: a car dropped with the hr's should be fully adjustable +/- 1degree. so if you take it to a shop that knows alignments. they should be able to adjust you back to where you need to be. If you still need more adjustment then buy the cusco upper arms for the front. $400.
good luck
read those 3 pages.
good luck
