IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
P0155 code, change o2 sensor engine ligh still on
Old 11-05-07, 03:46 PM
isc300t
isc300t's Avatar
Default P0155 code, change o2 sensor engine ligh still on
can somebody tell me what's wrong with my car , I got a code P0155 for the bank 2 sensor 1 heater problem , I got a brand new sensor already and install it to the bank 2 sensor 1. I mismatch the signal wire to ground ..then I switch it back, i"m not sure if that affect anything?
Out of the 4 wires, 2 of them goes in to the ECU , one is the 0-1v signal wire..what's the other one for? Heater 12v ? heater Ground? does it sense current or Voltage? because I want to see what's wrong with it... because it's a new sensor..what could go wrong?
Old 12-07-12, 05:08 AM
AZOBIS300
AZOBIS300's Avatar
Changed mine with an oem sensor still popped up someone help please
Rbeeber
12-02-18 08:42 PM
PandaGS300
04-06-15 01:40 PM
natman
Maintenance
12-26-13 03:50 PM
00&02rx300
RX - 1st Gen (1999-2003)
01-27-10 06:17 AM
jmoonan
Maintenance
12-07-05 07:36 PM
Quick Reply: P0155 code, change o2 sensor engine ligh still on
