rear diff..redline?
however you'll want to determine if your rear diff has an LSD or not - if so check the manual (which I'll probably be doing soon since mine is probably due and has an LSD) to see if an LSD additive is required.
per their website it sounds like you would want to use their additive:
http://www.redlineoil.com/product.aspx?pid=41&pcid=4
their 75w90... can't tell.... it doesn't specifically state it's needed but does say this:
"Helps with lock-up on weak limited-slip differentials-compatible with Red Line Limited Slip Friction Modifier for tuning slippage"
So I'm not sure why they would say it's compatible with their LSD additive but then say the oil itself "helps with lock-up on weaK LSD's"
Acrad
GX - 2nd Gen (2010-2023)
42
05-22-23 12:28 PM
