IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
SAFC Ratio & cam gear setting
Old 02-09-05, 07:34 PM
E12ic46
E12ic46's Avatar
Default SAFC Ratio & cam gear setting
For you people that have an safc tuned, what ratio did you guys go with? What is considered safe and dangerous. If you guys have dyno graphs, I would appreciate it if you can post it
For you people that have an exhaust cam gear tuned, what setting did you guys go with? How much degrees and did anyone every advance their cam gear? If so what would happen? thx guys
Old 02-11-05, 05:11 AM
Beachtyme
Beachtyme's Avatar
These types of settings aren't prepackaged, you need a tuner to get the most out of those mods and for it to be done correctly.
The 13-14 to 1 range is good for the SAFC.
Most of what I have seen for the exhaust cam gear is around 5-6% retarded.
Old 02-11-05, 05:49 AM
E12ic46
E12ic46's Avatar
Ok thx for the info...im trying to get as much info as I can.
finny76
GS F (2016-present)
15
07-21-19 01:14 PM
JessePS
02-27-11 05:48 PM
Gs3PoweR
Performance
05-12-03 01:57 PM
RysBURNER
Performance
02-19-02 07:42 PM
Quick Reply: SAFC Ratio & cam gear setting
