IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
fuel return/ fuel pump
Old 07-05-15, 01:10 PM
brett14
brett14's Avatar
Default fuel return/ fuel pump
i installed a FPR a while back and ever since then my car has been running very lean. i followed all the instructions out there and my tuner tells me its more likely a problem rather then it needing a new tune.
i adjusted the fuel pressure to 45psi with the vacuum not hooked up
there is 3 unknowns for me. if the stock fpr wasnt capped properly would that cause my problem?
could it just be a cheap walbro 255 that is going bad?
could the dampener cause this? i know the screw in it was coming out and i screwed it back in dont know if it had to be adjusted properly or what
any ideas?
davinciii
Performance
11-16-16 05:57 AM
nivekwb88
05-29-15 07:10 PM
Biggu
Performance & Maintenance
03-01-11 07:56 PM
S.F. Goat
07-26-09 12:34 PM
morris
15
12-22-06 03:18 PM
Quick Reply: fuel return/ fuel pump
