IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Fix or not to Fix
Old 07-02-15, 05:42 PM
henry5
henry5's Avatar
Default Fix or not to Fix
Hello everyone im new to the lexus community, i currently own a 97 ls400 coach edition and the starter is going bad on it as i have done some research. I work at a car dealership and i found a 2002 is300 with 127k on it its going for 4.2k the engine light is on and has 4 codes which are p0440 p0442 p0715 and p0763. i want to buy the is300 but idk if its worth fixing the starter on a car i own to financing this is300 with all the codes that are currently on it. I have driven it around in their parking lot and i am not mechanically inclined i didnt feel any struggle to shift in the gears as i drove and the "paddle shifting works fine" I just want to know which makes more sense my ls currently has 151k.
thank you all.
Old 07-02-15, 11:56 PM
IS3_FTW
IS3_FTW's Avatar
I googled each code ending with IS300. There are links about p0440 and p0442 are evap emissions BS. either vaccum leak, bad gas cap and cats or o2 sensors. The other 2 codes are little more complicated. Those codes i would do research on and determine if its cheaper to fix the starter, or jump into a car that will cost you more in the long run.
p0763 http://engine-codes.com/p0763_lexus.html
p0715 http://engine-codes.com/p0715_lexus.html
Davisito21
05-26-19 11:43 AM
Halon
09-21-16 07:44 AM
DieselEuro
04-21-16 06:22 PM
tommyt1777
11-05-13 10:14 AM
techtalk
09-02-11 01:12 PM
Quick Reply: Fix or not to Fix
