IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Brake bracket fit issue
Old 02-07-15, 02:37 PM
wake133
wake133's Avatar
Default Brake bracket fit issue
I was doing the brakes on my 04 is300 and the caliper guide pin broke off inside the front right brake bracket due to corrosion. So i bought a new bracket from Autozone a A1 Cardone part the part will not line up with the mounting points on the steering knuckle. Does anyone know what is going on with this? i already gave my old bracket to the store for the core fee. I'm assuming that the left and right front brake brackets should be mirror copies of each other but the one that i ordered for the right side has more narrow bolt holes then the left one. help please
Old 02-07-15, 02:41 PM
wake133
wake133's Avatar
does anyone have a oem right bracket they want to sell me
Old 02-08-15, 04:53 AM
drft_n_sc
drft_n_sc's Avatar
I'll have one available either tomorrow or Tuesday
I'll PM you once I have it off my car
Old 02-10-15, 06:04 AM
Cardone
Cardone's Avatar
Wake133, What part number did they give you? I'll double check to make sure they gave you the correct part.
Old 02-10-15, 06:56 AM
Cardone
Cardone's Avatar
The part numbers should be 14-1359 Left front and 14-1358 Right front.
Old 02-10-15, 01:34 PM
wake133
wake133's Avatar
yeah the part numbers are correct, 1359 and 1358. the bolt pattern on the left bracket was wide enough to fit but the right bracket was not. makes no sense that they wouldn't be mirror copies of each other. Why would the left have a wider bolt pattern and right be narrow?
Old 02-16-15, 06:35 AM
Cardone
Cardone's Avatar
Sounds like the right bracket must have been boxed wrong with a unit that is very similar.
I would order another on for that side.
Old 02-16-15, 06:54 AM
Nelexus88
Nelexus88's Avatar
If an OEM or different parts store bracket fits your knuckle then the Autozone bracket is obviously wrong. In order to get a refund, you should return the bracket soon before Autozone ships your original out. I would probably call the store manager first.
Have you owned your 04 IS since it was new? If not, there is a small chance the steering knuckle and brake assembly were replaced with a different (incorrect) unit sometime after the car was built.
Wilzzonn
RC - 1st Gen (2015-present)
05-03-18 12:59 PM
4everkidd
IS F (2008-2014)
05-21-15 11:47 AM
Ke0
03-09-12 03:57 AM
t.is350.h
Suspension and Brakes
03-08-07 01:43 PM
Quick Reply: Brake bracket fit issue
