IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS300 Rough Idle and Stall
Old 11-24-14, 12:48 PM
hzaidi26
hzaidi26's Avatar
Unhappy IS300 Rough Idle and Stall
Hi, a few days ago I started my car and soon as I went to drive it the car turned off. I tried starting again but it would not. Let it sit for a few and then gave it another try and figured that the car would, what seemed to me, misfire and then stall. I then tried starting it again and if my revs fell under 1500 rpm it would misfire and stall out. Drove it home without dropping my RPM's under 1500 and by the time I got home it was all good again. Thought it was just a malfunction.
Drove it the next day and after 10 miles the CEL light came on and TRAC OFF started flashing and the same thing happened again. Ran the codes and got a p1349 error.
Replaced the OCV filter and drove the car. It was fine until the car got warm. Started doing the same where it would stall out under 1500 RPM. It wont start unless I gas it while turning the key and now I have no CEL or any codes.
Anyone else had the same problem or know what it could be?
Old 11-24-14, 07:27 PM
hzaidi26
hzaidi26's Avatar
Thumbs up Update
Got another CEL today. Ran the codes and it was a P1656, oil control valve circuit malfunction. Replacing the OCV tomorrow.
NYGS300
03-30-15 06:19 AM
98GS300-2
Performance
63
01-05-15 06:31 AM
Duffguy619
11-05-13 06:27 PM
Dons98GS
12-15-10 08:06 AM
RI-Lex
02-05-10 08:04 PM
Quick Reply: IS300 Rough Idle and Stall
