IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
need all the wiring experts HELP!!!
Old 03-24-14, 04:54 PM
Wyzdum
Wyzdum's Avatar
Default need all the wiring experts HELP!!!
I have a 01 is300 and the cluster lights turn on but none of the needles work ... Also my security light keeps flashing even after I unplug the theft box ...
Old 03-27-14, 06:57 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
checked fuses, etc, I assume???
does the car start and run?
Initial thought is something wrong with the ECU, but the tachometer is not driven off the ECU, and if the engine runs, but the tach does not, then the ecu might still be bad, but there is something else wrong as well...
Old 04-16-14, 06:54 AM
LEDHI
LEDHI's Avatar
Try reset battery
Old 05-25-14, 07:40 PM
Wyzdum
Wyzdum's Avatar
I tried to reset the battery... The cats runs and drives great just that none of the needles read.. And the gear display doesn't show. All the lights light up tho ..that's why I'm stuck
Old 05-26-14, 02:22 AM
LEDHI
LEDHI's Avatar
There is also a plug that controls your dash odometer reading. Might be unplugged or bad harness. Not sure what the plug is called but it is located by your trans. Try search "odometer plug engine bay is300." It's illegal to unplug this plug cause it stops your odometer reading (if unplugged/damaged tach and speed needles don't work).
Old 05-26-14, 09:02 PM
Wyzdum
Wyzdum's Avatar
Do u know the exact location by any chance ? I've looked non plugs look unplugged.. And its weird that all the lights turn on but the needles and display don'twork
Old 06-02-14, 01:32 AM
LEDHI
LEDHI's Avatar
http://my.is/forums/f115/dont-work-s...er-mpg-441853/
Check out this forum this might help.
Old 06-06-14, 05:54 PM
Wyzdum
Wyzdum's Avatar
OK I think its either a wiring issue or BC I removed my abs... Idk bit I got all the lights in the cluster working ..still no needles work ..also the odometer screen is blank ...
JGWentwrth
09-17-18 04:30 PM
chperforma
20
08-21-17 06:53 AM
607is
Performance & Maintenance
09-12-13 04:26 AM
jlotz68
02-22-12 07:07 PM
510alex
11-29-06 12:33 AM
Quick Reply: need all the wiring experts HELP!!!
