IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
01 is300 spark plugs and wires replacement help!
Old 01-25-14, 06:23 PM
James4394
James4394's Avatar
Default 01 is300 spark plugs and wires replacement help!
I'm replacing my spark plugs and wires on the car and wondering if it is better off having a mechanic or dealer do it? Or if it's just better to do it myself? I changed timing belt and water pump on my own any thoughts? Also is there anything along the way that is worth replacing or changing rather get it all done one shot
Old 01-26-14, 06:59 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Plugs and wires are relatively easy if you've done a timing belt... Nothing else really in the area aside from coil plug boots you'll need three and three wires... Some people pull just the throttle body, I take the entire upper manifold off - either works...
Old 01-26-14, 11:37 AM
James4394
James4394's Avatar
Any part numbers for the coil plug boots?
Old 01-26-14, 12:45 PM
James4394
James4394's Avatar
And a price if u don't mind haha thanks for ur help
Old 01-27-14, 09:22 AM
mitsuguy
mitsuguy's Avatar
no clue from the dealer, I got mine from Autozone for $3 each
http://www.autozone.com/autozone/par..._713276_12753_
James4394
02-23-14 05:19 PM
vintagelex
02-05-13 01:15 PM
BloodlineX
02-10-12 10:50 PM
llllllllll
18
07-10-10 10:03 PM
One HoT
SC- 1st Gen (1992-2000)
06-26-03 08:04 AM
Quick Reply: 01 is300 spark plugs and wires replacement help!
