***HELP***IS300 is DE-ACCELERATING by itself. SLOWING DOWN
My 02 automatic is300 is not coasting or holding speed when letting off of the gas pedal. I feel and see the car de-accelerating quickly.
The mph needle will drop and slow down as soon as i let off of the gas. The engine does not feel free, feels more like it is in gear and slowing down when it should be coasting. For example reaching high speeds then letting off the gas pedal or going down hill off the gas pedal my car does not hold or gain speed....it slows down dramatically. This issue was not present ever before. I have a check engine light on for 02 sensor b1s1, i have not been able to replace it yet. So the check engine light has been on for about a month. I thought maybe a hub bearing, or tires but when i am coasting and the car is slowing..if i switch into neutral it will feel as if the engine was just free'd and will stop to de-accelerate and coast freely.
any thoughts ? THANKS in advance !
Sorry for the loud thread title. I am just extremely bothered by this issue.
any suggestion, diagnosing or solutions would be greatly appreciated
my 02 Auto IS300 decelerates as well, i dont think its an issue. if i go down a hill it coasts but on flat road it slows down. i thought this is normal. ive driven several cars that are sporty and all do this i assumed this was normal.
now if your going down hilll and your car is almost coming to a complete stop that may be an issue. just my .02 cents
i did check my trans fluid, it is at correct level on dip stick and the color is a pinkish purple some what dark. I also disconnected the neg battery terminal to reset the ecu. Im either loosing my mind or somthing is truly wrong here. I do NOT remember my is300 ever feeling like this. It would always coast. I was on the highway going 60mph, then let off gas pedal and the car would slow down immediately the mph needle would drop quickly and my car would slow down feeling as if it is in a low gear. Im afraid it may be a transmission issue.
At times it feel as if its coasting when off the gas and at others it feels to slow down quickly.
thanks for all the replies, anymore would be appreciated.
yes, what rpm are you at??? how do you know you're not in a lower gear? if something was dragging on the engine, it would have idling problems and wouldnt accelerate correctly
Thanks for your time
craig72
ES - 5th Gen (2007-2012)
41
08-09-17 11:46 AM
UpSideDown
02-13-17 08:23 AM
2007, 300, accelerates, de accelerate, engine, fit, gas, gear, idle, is300, low, problem, responding, slow, slowing down, srt
