Problem with the seat~!
Tried searching everything couldnt find. but basically my passenger seat got stuck when my buddy went to move forward and it wont move back i tried checking fuses took em out nothing the other seat works fine. heating seats dont even work on it eather. what can be the problem ?
Is it moved all the way in one direction? You can try loosening the seat frame bilts, it could possibly be in a bind (happens on older toyotas)... Also, spinning the shaft that moves the seat also helps... I know the motors overheat easy if you move them too much... Also, try a volt meter at the motor to check if it is getting power when the switch is pressed
