IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Timing belt???
Old 09-11-08, 01:59 PM
JoelD
JoelD's Avatar
Default Timing belt???
When do you really need to change your timing belt??? Is it 75,000 miles like most cars go by, or is it longer like 80,00-90,00???
Old 09-12-08, 08:33 AM
02IS-GTE
02IS-GTE's Avatar
i went all the way to 90k no problems, the dealer says i could go longer if i wanted too...
Old 09-12-08, 12:03 PM
Brian231
Brian231's Avatar
90k is about right for the 2JZGE. If you have never done a timing belt before, take it in. They are not easy to change and it is roughly $600. If you are off on the belt when installing the new one, you can cause great damage. There is a paper clip trick to know where the threading is when installing new, but I would have it done.
Old 09-12-08, 04:41 PM
anfro
anfro's Avatar
90 - 100k miles.
Old 09-13-08, 03:53 PM
2002GGPIS3
2002GGPIS3's Avatar
90k which is great for timing belt life. In comparison a mitsubishi eclipse belt is changed every 60k, and a porsche 944 is every 30k!
Old 09-25-08, 04:43 PM
IM QUIKR
IM QUIKR's Avatar
Pop the hood and remove the top timing belt cover. Inspect the belt for wear. Look at the smooth side for abnormal chipping, cracking cords, etc. Then carefully twist the belt to inspect the teeth. There shouldn't be any cracking of the rubber at the base of the teeth. Certainly note whether you are missing any teeth. If it looks like new and the rubber is holding up well 100K+ is no problem. Max life is probably 120,000 miles but for a safe margin of error Lexus recommends 90K miles. It's not a magic number that if you exceed 90K the belt will break. Belts have broken at 40k miles so if it looks good at 90K don't sweat it. Change it before 120k miles. Heat will deteriorate rubber the fastest second to chemical contamination.
Old 09-25-08, 06:45 PM
twestman
twestman's Avatar
pain in the butt to DIY the timing belt and water pump.... just take it to the dealer for that. its worth the money!
beehivejug
05-28-17 03:25 PM
tedsterb
12-02-14 09:23 PM
SEXYCOUPE4
Performance & Maintenance
08-28-07 11:44 PM
gslover603
02-02-07 02:55 PM
GSquicksilver
Maintenance
05-16-02 07:23 PM
Quick Reply: Timing belt???
