IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
is300 2001 car don't start
Old 09-01-08, 10:13 AM
is300links
is300links's Avatar
Unhappy is300 2001 car don't start
Hi, Need help... i bought a used is300 2001 that only came with one key, and then i lost the only key i had, so i called the dealership and they told me that the is300 "2001" model, that I can't just get a new key. I have to get a new ecu and key and get everything reprogram. That going to run over $2000. So, I look around and call this use is300 part place, and bought a used ecu and ignition set from a used is300 that they were parting out. So i replace the ecu, the key ignition all the wirer. But when i try to start the car. It crank, but will not start............. (the security light still blink) Doesn't anyone know what going on? Do i have to reset the ecu or reprogram the car????
PLEASE HELP!!!
Old 09-01-08, 03:38 PM
VIS250P
VIS250P's Avatar
HMM I heard it happen to other customer IS300 when he has problem with the car wont start.. I remembered a master tech told me that the car need to replace new ECU, reprogram the car key with techmaster computer and maybe the battery is dead.. I wish I can help u but Im in texas..
Old 09-01-08, 04:05 PM
IS3_FTW
IS3_FTW's Avatar
The ECU doesnt recognize the key, because the codes have been dropped.
You would now need to take it to lexus and have them reprogram your key to start the car. So basically, tow it or get lucky and have a tech come to your house.
Good luck
EDIT:
Here is a site that will help you. I was going to try a specific answer, but it seems like more than one issue.
Wont start
Old 09-28-08, 09:11 PM
JDMone
JDMone's Avatar
i would say,.. if the security is blinking after you start the car, that means the key that you have, has to reprogram so,..that means only lexus can do it with there computer......
palmdes1
04-24-19 07:02 AM
hshak2006
07-09-14 10:05 AM
e3customs
12-26-13 07:05 PM
k954triniz
07-24-12 11:01 PM
hit42
04-19-12 08:53 PM
Quick Reply: is300 2001 car don't start
