Hybrid Technology Unique topics related to the 2015 up NX300H model hybrid drivetrain and other features/options found only on the NX300H. Please use the main forum for discussion about shared components with other first generation NX models.
Slight ringing noise from hybrid system
Old 05-24-16, 03:29 PM
Balien
Balien's Avatar
Default Slight ringing noise from hybrid system
I get a slight ringing noise when the windows are rolled down and I'm either charging(braking) or in EV mode. If I am in drive and EV mode on a steep incline the car will make this noise constantly even though I'm not moving. It is not the fake noise from the speaker to warn pedestrians. That noise stops when you stop moving forward. Is it a electrical noise?
Car seems to work great. Sounds like a bad bearing. Is this normal for you other 300h drivers? Can't hear it at all with windows rolled up.
Old 06-18-16, 03:40 PM
TechNut
TechNut's Avatar
Ours does not make such a noise, and I would certainly be concerned if it was doing that. What is running while at a stop? Air conditioner motor perhaps? I wouldn't think it would be any part of the drive train as all the components, including the internal combustion engine, should be quiescent at a stop. The fact that an incline seems to exacerbate it would suggest it is part of the drivetrain however. I'm sorry, I realize I'm not being helpful at all, rather just thinking out loud.
I assume a visit to the dealer is in your near future. Please let us know what they find.
Old 07-07-16, 10:39 AM
jollick
jollick's Avatar
You may be hearing the wine from the motor/generator. If it is slight, it is normal. It almost sounds like a turbine. Hope this helps.
Peterun
Hybrid Technology
11-12-18 05:45 AM
Dukenukemx
08-21-17 05:54 PM
beavlexus
HS 250h Model (2010-2012)
04-09-12 06:40 PM
pinoiryder
02-07-11 09:50 AM
ChrisM910
04-25-06 01:41 PM
Quick Reply: Slight ringing noise from hybrid system
