Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
2011 RX450h OEM 12V battery capacity.
Old 12-13-15, 04:42 AM
Orchlon
Orchlon's Avatar
Default 2011 RX450h OEM 12V battery capacity.
Do OEM batteries for rx450hs have a lower capacity, cold cranking amps, or ampere hours? Due to a snafu I put one in my toyota crown (4gr-fse engine, same engine in an is250) and it's gone flat on me twice now. I heard the high capacity 330v batteries crank the engine in rx450hs so I'm thinking the 12v battery doesn't need to be as powerful and that's why it's going flat easy in my car. If the battery is already rated for a lower capacity I'll just swap the batteries again but if the battery is powerful enough to work in a gasoline only car I guess I'll get a new battery.
Old 12-14-15, 09:12 AM
Droid13
Droid13's Avatar
I don't know the specific rating of the battery, but what you said is true, the 12V battery is not used to crank the engine. It is only used to power the electrical systems. It is probably not a good choice for starting a conventional car.
krawfo
02-21-19 04:24 PM
MURTAZA
04-30-17 03:17 AM
jud149
02-12-14 11:20 PM
Matsui
GX - 1st Gen (2004-2009)
21
02-09-14 05:26 AM
Quick Reply: 2011 RX450h OEM 12V battery capacity.
