Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Tech refuses to use AISIN timing belt and waterpump kit
Old 11-17-15, 12:38 PM
vipergts
vipergts's Avatar
Default Tech refuses to use AISIN timing belt and waterpump kit
I purchased Aisin TKT-026 water pump and timing belt kit from Amazon. My tech (who I have used several times before) says these are not OEM parts and the "Mitsubishi" belt is not OEM. He says these are low quality parts and wont last as long as OEM parts. I am totally baffled. I thought these were OEM parts?
Old 11-17-15, 03:04 PM
fastnoypi
fastnoypi's Avatar
your tech needs to do a bit more research
Old 11-17-15, 07:59 PM
thomas1
thomas1's Avatar
your tech is wrong....I have used these kits twice, once on a Sequoia and once on my RX400h. They are same or better and very reliable.
Old 11-22-15, 07:12 AM
hypervish
hypervish's Avatar
Some mechanics fail to recognize parts as OEM unless it is clearly labeled and packaged as such. But, rest assured the Aisin kit is up to the task, and the parts are OEM. Aisin manufactured the original water pump.
Originally Posted by vipergts
snip... "Mitsubishi" belt is not OEM. snip...
And, while he has a point here.... OEM timing belt was made by Mitsuboshi! Slight difference in name.
RRGS
02-16-20 06:26 AM
gebo
Maintenance
05-14-15 07:22 PM
1320VR4
Performance & Maintenance
03-30-15 09:27 AM
rabbits
10-12-10 05:14 PM
pizdets17
08-13-09 10:00 PM
Quick Reply: Tech refuses to use AISIN timing belt and waterpump kit
