Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Check engine light came on..
Old 10-23-14, 12:45 PM
rsutoratos
rsutoratos's Avatar
Default Check engine light came on..
Still at work but it came on after I got to work. 79,600 ish. Gotta go home to get my reader.. I already check the gas cap. Anyone has their lights mysteriously come on ?
Old 10-24-14, 06:11 AM
User 41924
User 41924's Avatar
Nope. When ours came on, it was the gas cap. I may be wrong, but I seem to recall that it took a couple of minutes for the computer to realize I fixed it, and turned off the light.
When an injector went south on my Mom's RX, the dash lit up like a Christmas tree.Apparently, if there is something more serious wrong, the computer shuts down other systems (i.e. traction control), in case they might be impacted by the real problem. Good luck!
Old 10-24-14, 01:57 PM
wa3cuj
wa3cuj's Avatar
I had this happen on my 2010 450h several times. For whatever reason the gas cap would come loose and the light would come on. I would tighten the gas cap but it would take several days before the light would reset on its on. The dealer replaced the cap on at least two occasions. The last time they said that there was a tech bulletin out on this. I can't speak to that since I traded it on a 2013 a few months later.
Old 10-27-14, 05:17 AM
rsutoratos
rsutoratos's Avatar
P0302. It disappear for a few days and came back today
Old 11-02-14, 06:22 AM
FamilyRX
FamilyRX's Avatar
P0302 - Cylinder #2 Misfire Detected
Old 12-16-14, 09:32 PM
rsutoratos
rsutoratos's Avatar
So far, 1 coil pack replaced and 2 injectors. Engine still tapping and misfiring. They told me a lexus engineer is going to come out Thursday. Not sure how true that is or they're just swapping parts to see if it solves the problem.
Cars been in since last Friday. I have extended warranty. Ill see what else they fix
Old 12-17-14, 12:13 PM
Droid13
Droid13's Avatar
They'll probably replace $10,000 worth of parts before discovering it was a loose wire.
Old 12-18-14, 08:32 PM
rsutoratos
rsutoratos's Avatar
They were suppose to call me today, no calls, ill call them tomorrow. I wonder what else they found
Old 12-19-14, 07:52 AM
rsutoratos
rsutoratos's Avatar
They called this am, replacing entire all the fuel injectors and several seals and gasket. Wont see car till xmas eve.
I hope its fixed !
Old 12-19-14, 05:43 PM
surfRider
surfRider's Avatar
I hate to mention this but check for rodents. They do more damage than you can imagine. My friend had to put in a new engine as the rats had eaten through a temperature sensor wire and the engine overheated until it blew. On my Honda the check engine light kept coming on and it was an emissions vacuum connector on top of the fuel tank. They had eaten through it looking for windshield washing fluids for the rear window. That they had already drained.
Look for dropping in the engine compartment..
Old 12-30-14, 08:02 AM
rsutoratos
rsutoratos's Avatar
Got the car back today, after 2 weeks, due to parts and holiday
TSB L-SB-0045-12
Replaced 6 fuel injectors
23209-31160
23291-28020 - insulators
25627-31030 - EGR gasket
17179-31010 - Intake manif gasket
17176-0P021 - Air Surge gasket
Old 12-30-14, 09:30 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Thanks for the update. Let's hope that's the end of the check engine light. Happy New Year!
Old 12-30-14, 06:19 PM
Cruiter
Cruiter's Avatar
I've not heard of one car having that much go south. Must have started as one thing causing failures down the line. Anyway, glad it's all done. Enjoy tomorrow and Happy New Year .
TSB L-SB-0045-12
23209-31160
Old 01-05-15, 10:23 AM
rsutoratos
rsutoratos's Avatar
Yes, luckily i bought the extended warranty, i drive about 25-30k a year.. lexus service only. The engine tapping sound is gone too.
Old 03-29-15, 10:36 AM
danmadio
danmadio's Avatar
I have a 2010 RX 450h which I bought new. Always garaged, regular maintenance. Just added Chevron Techtron injector cleaner to a tank of premium gas. Cold ambient temp. Drove about 200 miles (highway and local) and parked in garage last evening.
Took car out this a.m. and had check engine light on (steady).
I am going to try the gas cap. Any other thoughts/suggestions?
Quick Reply: Check engine light came on..
