Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
07 GS450h strange noises
Old 05-15-14, 05:48 AM
rhwimmers
rhwimmers's Avatar
Default 07 GS450h strange noises
I've noticed there is eomthing being "pumped" on a regular basis, even after the car is off. I opened the hood and the top right section (standing in front of the car) has a metal square with several tubes running in/out. This is what keeps turning on, seems to me its pumping something, somewhere. It happens while driving, stopped and even after car is off and im walking away from it. I fear its going to kill my battery at some point, or that something is empty but it keeps trying to pull something?
Any thoughts?
Old 05-16-14, 04:35 AM
Stoodo
Stoodo's Avatar
All hybrids make weird sounds after the car is off for a period. (At least Toyotas)
Old 05-16-14, 03:09 PM
rhwimmers
rhwimmers's Avatar
Yeah, my wife drives a HiHy and it too makes strange noises - but the frequency of mine seems to be something wrong?
I went out to get something from my car hours after it was parked, unlocked it, got in, locked it, and it started making the noise as I was walking away...
Old 05-16-14, 03:28 PM
1QWKGS4
1QWKGS4's Avatar
Weird.. good to know as i "Was" considering a 450H.. lol
Old 05-16-14, 04:08 PM
Stoodo
Stoodo's Avatar
Yes, you better avoid the 450h and well, any mechanical device for that matter. (lol)
Old 05-16-14, 04:13 PM
Brabusx2
Brabusx2's Avatar
my hybrid make "squossh squeeak" noise when i am lightly accelerating. sometime let off it will make sound, starting to brake it make that sound, i will try to see if i can record a video clip of it
and no, i am not talking about the battery or motor humming sound
Old 05-16-14, 10:42 PM
01LEXPL
01LEXPL's Avatar
The manual is a good resource for this...
When I got my mom a CT200h, I heard the thing making noises hours after use or during.
Sure enough, a look in the manual explains all.
It's all 'normal' for Toyota hybrids.
Old 07-20-14, 09:00 AM
rhwimmers
rhwimmers's Avatar
My brake warning lights, vsc,etc all came on..said I needed 500 brake job (rear rotors, front turned, all new pads) got that done, lights came back on again. Take it back and he reset it but said he thinks the unit that pushes fluid to the brakes is going bad and to go to dealer...I'm pretty sure this is the unit that's been making the noise more frequently. He said if you knock on the unit it turns it on, I haven't verified that yet.
Any ideas what could be going on?
Old 07-20-14, 09:35 AM
ThomasGS4
ThomasGS4's Avatar
ABS actuator. Common issue with 430/450h/460 as the brakes are electronic. 300/350 are hydraulic.
Old 07-26-14, 02:49 PM
rhwimmers
rhwimmers's Avatar
Easy to fix by myself? How much am I looking at?
Old 08-06-14, 08:36 AM
rhwimmers
rhwimmers's Avatar
Took it to dealer...says I need a new ecu for $2400, and maybe the actuator but the ecu got so hot it stopped talking to their computer? I've brought this to autozone a couple times and had them read the codes which were low voltage in braking system, but no one ever mentioned it got too hot to touch, maybe they didn't have it hooked in long enough to notice the heat? Thought that was strange.
Said my abs won't work or anti skid stuff but because brakes are hydrolic they would still be fine.
Any thoughts? Can I get a used ecu?
XxGoKoUxX
08-26-15 10:48 PM
JWH64
GX - 1st Gen (2004-2009)
08-03-13 09:41 AM
JFNash
04-10-12 08:36 AM
munister
06-20-11 07:24 AM
MJMeucci
04-29-08 04:34 AM
Quick Reply: 07 GS450h strange noises
