can someone please check you head lights and see if its normal
Hello fellow Lexus driver,
I just got my vehicle back from Lexus after a whole week of "replacing headlight".
And night just fell and i was looking at my cut off and it seemed lower from the side they replace under the moisture warranty (mine went out). I have attached pictures please see if one of your headlight's cut off is higher than the other. I want to verify my claim before going back to the dealer.
Also why do my pictures always unload upside down even if i rotate it to be right.
You can adjust the headlight height for left and right yourself, with an adjustment screw on each headlight. This will establish the baseline height that the auto level control will keep depending on the load of the vehicle and angle of the road. It should be slightly lower on the left side (for left hand drive models) to keep from blinding oncoming traffic.
The main thing is that you can see the road well and you are not blinding people.
Mine is a little off just like yours on the drivers side, I can find / see the top screw to adjust but can't find or k
know what to look for the second screw the adjust ...any help?
Thanks Chris
Thanks Chris
There are two screws...not one....The owners manual has pictures and instructions. For every turn of the one screw you have to turn the other screw a certain amount as well.
I will double check I looked but didn't see then info in the manual . The top one is easy but can't find the bottom or the other one. I have to take it to lexus so they can take pictures then send it in the Lexus to see if I get a new light
do you just have cosmetic flaws? or did you headlight go out and afs light come on
Not good
Sorry to hear that , I'm still waiting on mine . I have to take to Lexus and they take pictures and send them in to see if I get it fixed. Even though they said last visit , which was 3 months ago that it had the issue.
sojah
10-07-09 06:23 AM
SerasLibre
08-17-09 09:54 AM
