Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
plug-in for RX hybrid series
Old 12-17-13, 09:27 AM
jeff3113
jeff3113's Avatar
Default plug-in for RX hybrid series
Hello,
I am a new member and have a question about the RX hybrid series.
I am currently looking for a 2010 RX 450h.
I'm curious about whether anyone has converted that system to a plug in.
I have solar panels on my house and have an abundance of power available for charging.
I've noticed the RX hybrid lists it's battery pack at 37kwh. That seems like a large amount of available power storage.
Naturally, using that capacity would be a big benefit.
Other PHEVs seem to have similar storage.
many thanks for insights,
Jeff
Old 12-17-13, 10:15 AM
Droid13
Droid13's Avatar
The RX450h hybrid battery has a power output rating of 37kw, it does not have a capacity of 37kwh. A capacity of 37kwh would suggest it is capable of supplying it's maximum power output of 37kw for 1 hour, which it certainly cannot do. More likely, just a few minutes worth at best, which would put the battery's capacity at 3kwh, as a guess. I don't recall ever seeing the capacity listed. It's a bit meaningless anyway as the NiMH batteries used for non-plugs are not designed for deep cycling associated with plug-in use. They are controlled by the vehicle electronics for short periods of charge / discharge cycles within a small range of the battery's actual physical capacity, in order to extend the life of the battery. If this battery was used in a plug-in environment with full charge/discharge cycles it would be dead in 12 months.
tempestv8 (03-06-18)
Old 12-18-13, 07:39 AM
vlad_a
vlad_a's Avatar
As Andy has pointed out, hybrid batteries usage is optimized for longevity instead of power delivery. There is a very narrow operating discharge range, somewhere between 60% and 70%. The best you can get is 2 miles out of it. The nature of the hybrid is to use the battery as a buffer to optimize engine loads and recuperate braking energy. It also allows the engine to run on http://en.wikipedia.org/wiki/Atkinson_cycle instead of a traditional http://en.wikipedia.org/wiki/Four-stroke_cycle.
You could opt to purchase a plug-in Prius. That will get you the best of both worlds. However, even in that setup. it has a dedicated battery for the EV-only range of 13 miles. Once it is depleted, the hybrid system will not charge it, and it will be just a dead weight, no pun intended.
jdlierle
Hybrid Technology
15
09-16-16 04:26 PM
johnsrx300
Hybrid Technology
11-30-14 11:14 AM
Fiddledd
RX - 3rd Gen (2010-2015)
19
10-23-11 09:02 PM
Mdkellys
09-13-11 04:05 AM
MPLexus301
Hybrid Technology
06-18-09 04:14 PM
Quick Reply: plug-in for RX hybrid series
