Leaking radiator
Leaking radiator
2008 RX 400H radiator started leaking. Replaced it today and found a crack in the housing. Went for a test drive and turned up the heat to high. I live in NJ and it was rather cold today. Was only getting cold air and observed the climate control was on air conditioner even though it was set to high. The job was done at home and I did not bleed the system. Does anyone know if the system has to be bled? If it does can anyone give me the instructions to do so. All the reservoirs were filled.
radiator replacement
Picked up my 2006 rx400h after the radiator was replaced and ac and heat did not work properly
Temperature sensor in front of radiator was not plugged back in. Plugging it in solved the problem
How many miles were on the RXs when the radiators failed? My experience with Japanese cars is that the plastic top of the radiators frequently crack between 130K and 160K. Seems to be more mileage related than age. Experience is with 2000 Mitsubushi, 1992 Lexus, 1997 Honda.
Steam coming out of the front grill should be investigated. It could be a leak/crack in the radiator or a hose leaking. If it is steam from the cooling system, the coolant in the reservoir should be low. You need to remove a trim piece to get a good look at the top of the radiator where cracks usually occur in my experience.
thank you getting it checked out!
Yup major crack on radiator opposite side of upper hose...about 3 inches long. Ordered one from Rock auto (denso) hope it turns out to be a easy task...
OK received radiator from Rock Auto, (Denso brand) and it looks exactly like the original. I found you can replace it without removing the bumper cover. The rivet looking thing on the hood latch assembly for the front bar is actually a plastic cover which can be removed to access a 10mm nut. Than the top radiator mount can be unbolted and swung away. There are two bolts on the very bottom of the radiator that can be accessed by lifting the radiator with the condenser and putting a block of wood under it so you can unscrew the 13mm bolts that hook the bottom frame to the radiator. I am back in business now. About $110 with shipping.
the Denso is a one row, like the OE and made in Taiwan...Great quality by looks and construction. Not a bad job except for dropping one of the bolts in bottom of radiator into a hole in frame. Had to retrieve with a magnet.
I don't know, disturbing that stuff sometimes get you trouble. With the new anti-freezes coolants these radiators stay relatively clean. not like the old days when you would get deposits and rust accumulation. Funny note you can get the plastic tanks for $90 apiece, but with radiators that cheap why bother.
