Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Dealer Wants $2200 for Brake Actuator
Old 03-25-13, 11:45 AM
beejohn
beejohn's Avatar
Default Dealer Wants $2200 for Brake Actuator
My car is making a dying seal noise when I push hard on the brakes (even at a stop). Basically if I push the brakes really hard up and down it makes a squealing noise.
I called the dealership, they said it could be the brake actuator which is $1600 + labor. But that they recommend flushing the fluid first. I took it to my local mechanic and they said the brake fluid has less than 1% moisture and it isn't required to flush the fluid (fluid was last changed about 2 years ago in Feb of 2011). The independent mechanic said don't waste your $ with the brake flush and just get the actuator changed.
What do you think is a reasonable cost to replace the actuator? Is it a DIY project? If not, does anyone know any reasonable mechanics in Southern California who can do this?
I was also contemplating getting a warranty for the car since this repair is $2000! Any advice? It's a 2007 RX400h with 83,xxx miles. Thanks in advance
Old 03-25-13, 01:14 PM
maseace
maseace's Avatar
Apparently any job involving bleeding the air from the brake fluid is not a DIY job for this hybrid, because you need the Lexus computer to command the electronics in the brake system to bleed it properly. Is the squealing sound something that happens with normal braking, or only hard pushes on the pedal?
Old 03-25-13, 08:40 PM
thomas1
thomas1's Avatar
I would also suggest flushing the fluid first, Toyota can do it for around $120 or less...That was what I was quoted.
Old 03-25-13, 08:48 PM
thomas1
thomas1's Avatar
Too bad we dont have part number, the brake actuator is hard to find in the parts lists. The computer cost around $1600, but the actuator assembly is only around $162....
Old 03-26-13, 10:16 AM
riwyle
riwyle's Avatar
There is a TSIB #BR003-7 Regarding brake noise. The recommendation is to bleed the ABS Actuator, which requires a special tool. (Not Flushing the fluid as the dealer recommended- that doesn't make sense.). If this doesn't solve the problem, they then recommend changing the actuator. This had to be done on my 06. No reason a Toyota dealer could not do it and probably at a lesser cost than the Lexus dealer
Old 03-26-13, 04:02 PM
thomas1
thomas1's Avatar
When I said flush I meant bleed...And toyota gave me the quote....
Old 12-23-13, 12:07 PM
svidas
svidas's Avatar
My 2010 RX450 just had the ABS Actuator assembly replaced under warranty. They listed part 896051N and 44050-48320 but no price since under warranty. I couldn't locate those numbers at Sewell.
Old 12-24-13, 06:18 PM
Uzairlexus
Uzairlexus's Avatar
http://www.ebay.com/itm/2013-Newest-MINI-VCI-FOR-TOYOTA-Software-TIS-Techstream-V8-00-034-/190817243722?pt=Motors_Automotive_Tools&hash=item2c6d98124a&vxp=mtr
thats a tis (TECHSTREAM)
its what toyota/lexus uses to bleed the brake fluid
of course they have a licensed version
this is great i have used it many time on many different vehicles
so a diy is possible i dont know exactly how but this helps ( I hope)
Old 12-25-13, 09:47 PM
CRD
CRD's Avatar
Interesting. Can you set the optional car programing with this software? Things like remote door programing, headlight delay, etc?
Old 12-26-13, 10:54 AM
Uzairlexus
Uzairlexus's Avatar
yes
the also has a "passive security system" which is default to off i also turned that on and its very nice
you can control everything in the car for example afs, windows, radio, nav, trunk, beeps, move the afs headlight, record car data, reset check engine, diagnose airbags, and many more its very help full, program new keys, re-flash ecu, program tpms sensor
IMO it's a very good investment
Old 12-26-13, 08:18 PM
CRD
CRD's Avatar
Sounds good. For $28 I will order it. Thanks!
Old 12-30-13, 12:29 AM
aucht
aucht's Avatar
where do you learn to use this program?
Old 12-30-13, 04:42 AM
maseace
maseace's Avatar
There is no manual with it. Each function has a short description before you execute it.
Old 12-30-13, 08:42 AM
Uzairlexus
Uzairlexus's Avatar
Just like maseace said short description and I learned the old school way, trail and error. You cant really mess up anything, everything has a reset to default button so...
Old 12-30-13, 12:01 PM
CRD
CRD's Avatar
btw, what does the "passive security system" do?
Quick Reply: Dealer Wants $2200 for Brake Actuator
