Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
Hybrid Transmission and (Rear diff) 90k fluid change
Old 04-06-13, 05:04 AM
Speedy0o
Speedy0o's Avatar
Hmmm, not very helpful from their part! I was told they have a warranty on the hybrid system to 7 years or 130000miles, mines done 132000 miles now and is coming up to 8 years old (2006 model) so I'm over the warranty limit and wondered if an oil change was a good idea!
Starting to get the point where I don't want to pay "main stealer" prices anymore and there isn't any specialists within 50miles of me! So if i can drop the oil and refill for the sakes of the price of the oil I'm sure it won't hurt it! Mercedes when they released their 7g tronic autoboxes said that they would never have to have the oil changed, then as they started getting failures, changed their minds and were quick to add it to a service schedule!!
Also looking on the parts diagram there appears to be 2 drain plugs on the sump of the box! which indicates that it would be a serviceable item and wouldn't require any special technique to remove the oil! Not sure about refilling though!
I know of some audi's that apparently have a special pump system to pump the fluid back into the box via the drain bung! Not 100% sure about that though!
Old 06-03-13, 07:25 AM
sonnyhood
sonnyhood's Avatar
I would appreciate a couple of pics if your doing yours, any tips you find along the way.
Old 08-18-13, 04:34 PM
pngo121
pngo121's Avatar
havent taken a look at my 450h thoroughly but on my 12 tundra and 06 tacoma the transmissions are closed systems so you would have to pump the oil back through the drain plug. might also need to get the manual to see how to reset everything also after your done. again, i havent taken a look at it yet but just throwing this out there so people dont flush their car and end up having to tow it to the dealer.
Old 08-20-13, 04:41 AM
ibidu1
ibidu1's Avatar
Maybe this will help you guys
Old 08-22-13, 12:39 AM
sonnyhood
sonnyhood's Avatar
Mechanical Catalog - 2007 - Lexus - GS450H
maintenance & lubrication, transmission, automatic transmission, filter GS450h
$91.10
maintenance & lubrication, transmission, automatic transmission, pan gasket GS450h
$33.24
https://www.lexusparts247.com/gs450h-parts.html
This looks like the parts i need, im booking mine for an inspection next week, then ill order these if my trans service mech agrees i need these. Toyota CVT oil will be a standard part aswell i assume available anywhere.
Ill try take some videos and photos of how it goes if he will let me.
Old 09-20-13, 06:04 AM
sonnyhood
sonnyhood's Avatar
can someone post or msg me a vin number of a car in usa.
2007 GS450h with out active stabiliser suspension (with sport suspension button if poss)
I want to request correct gearbox service parts and they dont accept mine from Australia.
Im assuming gearbox service parts are all the same.
I will post my findings. Just ordered 4 new shocks and want to order more bits.
Old 11-13-13, 06:04 PM
sonnyhood
sonnyhood's Avatar
https://www.clublexus.com/forums/gs-...ml#post8235691
Just found this link, ***DIY: Rear Diff Oil Change (w/ pics)***
alchemist says he changes it every 30k miles? but i dont think mine has ever been done
Old 11-16-13, 09:50 AM
Speedy0o
Speedy0o's Avatar
The item highlighted says strainer assembly, perhaps this is the filter then? Pretty expensive for a shaped metal box with filter-paper/gauze inside it!!
oh and for sonnyhood thats the part numbers there!
Attached Thumbnails Hybrid Transmission and (Rear diff) 90k fluid change-gsh-gearbox.png
Old 11-27-13, 09:35 AM
neurocity
Neu`roc´i`ty
neurocity's Avatar
You're assuming its the same filter as a normal transmission. Part number and price is normal.
Old 12-02-13, 06:33 AM
Speedy0o
Speedy0o's Avatar
That is a GS450h CVT with parts listed as they are, cant see the filter being any different, it doesnt have to do any other job apart from catch debris and metal filings/fragments that will eventually work loose over time!
Had my transmission oil changed at a specialist lexus dealer last week, he reckons it had never been done in all the 152k miles my 450h had done and said the oil was black as apposed to a nice pinky colour! The oil is unique to lexus/toyota apparently according to the chap i spoke to to and is called ATF-WS and its only made in japan by Toyota themselves so you can only get it via dealers or specialists (so he said anyways) He didn't BS me on anything else my car was in for so inclined to believe him! Didn't cost the earth either!!!
Wood3000 (05-23-21)
Old 03-07-14, 02:35 PM
gripau1
gripau1's Avatar
The Toyota ATF -WS is the current auto transmission fluid from for all Toyota/Lexus cars from 2005 on wards. ATF-WS (world standard) is suppose to be a life of the car transmission fluid.
I'm just wondering how do you do a transmission drain and fill on the GS450h? Is there a separate filler hole if there is no dip stick?
Old 03-25-14, 09:53 AM
Sania56
Sania56's Avatar
This TSB will help you
File Type: pdf
The following 3 users liked this post by Sania56:
dkotanto (12-14-20), Farqui (02-16-18), Wood3000 (05-23-21)
Old 01-28-15, 12:43 AM
mr. tetsuo
mr. tetsuo's Avatar
got both of these fluids replaced by the dealer not too long ago.
did anyone else see a drop in MPG? i went from 25 tank avg to 23 ish tank avg. maybe i need to let it break in more?
on the plus side, my hybrid battery gets to the green level with just city driving lol.
Old 02-01-15, 06:46 PM
sonnyhood
sonnyhood's Avatar
Default transmission hybrid CVT
Hi There,
just had my service done for 180,000kms and requested a trans fluid change.
they said its a 5.5 hour procedure and 7 pages of instructions as per lexus guide.
And were pleading with me not to have it done?
They informed me its not transmission fluid, its some coolant linked to the hybrid drive system.
And the fluid never fades or wears out and not to replace it.
Even new gearboxes they replaced come pre-filled with fluid from Japan.
Even i pushed and said replace it anyway, they advised against it.
Whats the deal here?
Old 02-01-15, 06:51 PM
sonnyhood
sonnyhood's Avatar
Ill send this and the image above to my lexus service centre and see what they say.
It seemed like they were actually scared to replace the transmission fluid?
Quick Reply: Hybrid Transmission and (Rear diff) 90k fluid change
