Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
CVT and rear Differential plugs
Old 03-02-11, 08:22 PM
thomas1
thomas1's Avatar
Default CVT and rear Differential plugs
Ok guys my first maintenance, my new to me 2008 RX400h has an unknown on the CVT and Rear differential fluids changes...WS? and here are the pictures are these the plugs for drain and fill..circled in red. CVT 4 qts? and Rear 2 qts?...Thanks for the help oh and 88 almost 89k miles on the car...
Attached Thumbnails CVT and rear Differential plugs-p1150603.jpg   CVT and rear Differential plugs-p1150609.jpg
The following 2 users liked this post by thomas1:
Bennywon (06-21-20), vincentime (12-10-20)
Old 03-03-11, 05:19 AM
rcy
rcy's Avatar
I answered this in the other forum, so not going to repeat all that info...
However, is the CV boot leaking grease? (the rubber boot on the shaft leading to the rear diff). It looks like it in the pic. If it is, you may want to get that dealt with sooner rather than later.
Old 03-03-11, 05:30 AM
thomas1
thomas1's Avatar
its raining here, I didnt see any tears, lots of water dripping from the bottom...
Old 03-03-11, 05:59 AM
rcy
rcy's Avatar
Oh, maybe it's just wet then. Hopefully...
Old 03-04-11, 05:19 AM
gscott2
gscott2's Avatar
Default Link to other thread?
Could you post the link to the other discussion where you addressed the CVT drain/fill bolt issues? I couldn't find it via search. Thanks.
Old 03-04-11, 07:02 AM
thomas1
thomas1's Avatar
It was on the Lexus owners club site...I posted both sites...
Old 03-04-11, 09:40 AM
rcy
rcy's Avatar
www.lexusownersclub.com
Old 03-06-11, 08:18 AM
thomas1
thomas1's Avatar
Ok changed the fluids, 4 qts front 2 qts rear...89k miles front fluid was dirty, rear not bad. here is sample on paper of old and new from front.
Old 07-24-12, 06:16 AM
Iluvlexus
Iluvlexus's Avatar
Anyone have the part # for the plug gaskets?
Thanks, Scott
Old 07-24-12, 06:25 AM
thomas1
thomas1's Avatar
Go to se
well Lexus site and you will find it. They are just crush aluminum washers
Old 07-24-12, 08:55 AM
Iluvlexus
Iluvlexus's Avatar
Thank you Thomas1. Did you just pull both plugs to drain, replace the bottom one and use a hand pump to move the WS quarts into the fill hole until it runs out? Just like a rear end?
Thanks, Scott
Old 07-25-12, 06:39 AM
thomas1
thomas1's Avatar
Yep exactly what I did. Kind of a pain but easily done in less than 30 minutes.
Old 07-26-12, 10:52 AM
Iluvlexus
Iluvlexus's Avatar
For those interested, the washer part # is 9043018008 and it is available at the Toyota dealer
Old 08-07-12, 06:34 PM
Iluvlexus
Iluvlexus's Avatar
One last question. Is the removal bit a 10mm hex?
Old 08-07-12, 09:08 PM
thomas1
thomas1's Avatar
yep believe it is 10mm....
Quick Reply: CVT and rear Differential plugs
