CVT and rear Differential plugs - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 08-11-12, 02:45 PM   #16
Iluvlexus
OK. Finally did it. Was quite easy with excellent access to the drain and fill plugs..Neither fluid was particularly bad with the CVT darker than the rear. Only issue was the CVT must have had 6 quarts in it. I opened up the fill plug and it came pouring out. Wonder why it was so full? As other have noted, the CVT took 4 quarts and the rear 2. Thanks to all for your help.
Scott
Iluvlexus is offline   Reply With Quote
Old 08-11-12, 03:39 PM   #17
thomas1
thomas1's Avatar
good job. What was your mileage?
thomas1 is offline   Reply With Quote
Old 08-11-12, 09:17 PM   #18
Iluvlexus
Sorry, meant to state that. 97K. My fluid appeared much cleaner than yours. Anyone else note that the factory fill is quite generous?
Old 02-10-13, 06:35 PM   #19
MeryLexmas
If I were to drain it, I would put it into a container where I could measure how much came out. It would suck to have 6qts come out and only be able to replace 4. If Lexus considers it lifetime fluid, there is a chance that you may not be able to put in as much fluid as they put in originally during assembly.
MeryLexmas is offline   Reply With Quote
Old 05-08-13, 05:06 PM   #20
thomas1
thomas1's Avatar
Here is my latest tranny fluid comparison after 18k miles at 129 total k on vehicle....note dirty fluid on left.....That is from driving hard to LA/Sacramento many times...at 80plus mph.
Old 08-03-13, 05:13 AM   #21
retiredguy
Rule #1 is to always....ALWAYS crack open the fill plug BEFORE opening the lower drain plug. That way you know that you will be able to replace the fluid. I've seen many times people open the drain plug, drain the fluid only to find out the fill plug is frozen shut.
retiredguy is offline   Reply With Quote
Old 04-18-14, 04:08 PM   #22
kwanyu
Thanks for the great writeup guys. Took me 30 minutes to do both front CVT fluid and rear diff fluid on my 130,000 mile 2006 RX400h.
Fluids were fairly dark for me. And I want to say the car feels a lot smoother but I'm sure it is just in my head.
I'd highly recommend a decent sized wrench, along with a lot of rags for the job, and an extra quart of oil nearby.
kwanyu is offline   Reply With Quote
Old 04-18-14, 04:54 PM   #23
thomas1
thomas1's Avatar
Your welcome....Glad it went so smooth, my old bones are moving slower, maybe you should do mine for me again, it is due in 500 miles.
Old 04-18-14, 06:00 PM   #24
spacecraft
One question for those who already did the job:
What about the CVT oil radiator behind the bottom of the front bumper, on the driver side?
Is there a way to drain it also, or did you just accept to leave some old oil in the circuit?
spacecraft is offline   Reply With Quote
Old 04-19-14, 07:40 AM   #25
thomas1
thomas1's Avatar
I just elected to drain and fill, seems to clean up everything quite well. After two changes the fluid was great looking.
Old 04-20-14, 08:03 AM   #26
spacecraft
Thanks for your feedback.
I just realized that this matter is not specific to the 400h, so I thought to follow up on the "Transfer Case and Differential Oil" thread, in the generic RX 2nd gen section.
Thanks in advance to anyone who has further thoughts on this topic for following up on that thread, just to avoid splitting the same discussion...
http://www.clublexus.com/forums/8494980-post34.html
Old 04-21-14, 10:06 AM   #27
kwanyu
I don't know if I have the oil cooler radiator, but it does look like I have two radiators. I had assumed it has something to do with the hybrid cooling but maybe it was for the tow package (I have a hitch but I never used it).
Either way, even if you have the oil cooler radiator, wouldn't a second drain/fill essentially just clean the majority of the oil assuming the oil circulates properly?
Old 04-21-14, 08:17 PM   #28
jimboesfo
I don't think that a second drain and fill would be worthwhile.
From the owner’s manual for transmission drain and fill capacities:
3.9 qts without tow package
4.1 qts with tow package
The service data sheet (thanks maseace) indicates 4.4 qts. I assume that this is the total system capacity. So it would appear that at most only 0.5 qts (about 10%) might remain in the system after a drain and fill.
jimboesfo is offline   Reply With Quote
Old 04-21-14, 09:55 PM   #29
thomas1
thomas1's Avatar
Yes what I did the first time was wait a 1000 miles and then do the second change. This was because I bought the vehicle with 87k miles and the fluid was really brown. After the second change the fluid was a bright red.
Old 08-08-14, 06:53 PM   #30
maximizese
I'm preparing to do a CVT fluid change and was wondering how you all pour the fluid into the fill hole. Can this be down topside from the engine bay with a flexible funnel or do I need to use a siphon/vacuum pump from underneath?
maximizese is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2011 ISF Differential Fluid Change questions. wiloz32 IS F (2008-2014) 8 12-21-15 10:11 PM
IS350 Wheel Size ramlawih IS - 3rd Gen (2014-present) 1 03-01-15 02:01 PM
RX400h Transmission fluid change chinalfr Hybrid Technology 9 07-18-11 11:26 PM
Rx330 Awd Fluid Replacement Question FZ6 Dude RX - 2nd Gen (2004-2009) 9 07-07-11 02:42 PM
Different and transfer case fluid change brickauto GX - 1st Gen (2004-2009) 4 04-07-08 07:43 PM
Tags
08, 2008, 89, car, club, cvt, differential, drain, end, lexus, maintenance, pictures, plug, rear, rx400h
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
