HS 250h Model (2010-2012)
Changing the fuse - cig lighter adapter in center console
Old 01-30-15, 11:15 AM
dustin2413
dustin2413's Avatar
Default Changing the fuse - cig lighter adapter in center console
I think the fuse box is located on the drivers side under the hood, any idea which fuse it would be for this power adapter?
Old 01-30-15, 01:15 PM
Clutchless
Clutchless's Avatar
Received 1,091 Likes on 931 Posts
The owners manual should have a guide to which fuse operates which part. Also, when you open the fuse box, there is usually a guide inside the lid. If it is blown, start removing and replacing fuses until you find the one with the broken wire.
Also there is usually a second fuse box between the drivers door and dashboard on the side or under the dash.
Old 02-07-15, 01:32 PM
TheAirman
TheAirman's Avatar
It's fuse # 33 (15 amp) inside the fuse panel, under the steering wheel, on the drivers side, by your left knee.
pentiumvi
RX - 4th Gen (2016-2022)
38
01-16-24 05:33 PM
SoCal Cyco
12-01-22 04:29 PM
mjolla
06-05-21 12:49 PM
RCF303
RC F (2015-present)
03-28-18 11:29 PM
ALLWiTE2JZ
SC- 1st Gen (1992-2000)
10-23-11 03:09 PM
Quick Reply: Changing the fuse - cig lighter adapter in center console
