HS 250h Model (2010-2012)
front defroster
Old 10-24-14, 07:01 AM
nht48823
nht48823's Avatar
Default front defroster
I am not sure if its working probably - when I click the button for the front defroster instead of green light, its orange. is that normal?
the fan does come on and it does clear up the windshield. when I view the settings in my navigation under climate - I cant tell the mode, the AC is not lid either. I know most cars when you turn on front defroster the AC automatically comes on....
Old 10-24-14, 08:06 AM
Clutchless
Clutchless's Avatar
Received 1,090 Likes on 930 Posts
Check settings, if you have Nav, there are many settings you can access thru the screen, to see if AC is set to Auto. If so, it will come on with defrost.
Old 10-25-14, 10:34 AM
nht48823
nht48823's Avatar
i checked nothing related to defroster/AC settings. whats strange is defroster light is orange I seen it green so I am not sure at what stage it changed. i only had this car for about 2 months so I am not 100% sure if it suppose to be orange or green like the rest
Old 10-25-14, 04:28 PM
TheAirman
TheAirman's Avatar
In your "Vehicle Settings", if you have the NAV, under "Climate Settings", you'll find:
"Efficient Ventilation Mode"
This is the setting you are looking for. It is responsible for turning on the A/C compressor to blow dry air when you select the front defroster. The default setting is "ON". So to answer, most likely when you hit front defrost, it does turn on the compressor, and the light was orange, if I remember.
The other setting is "Auto A/C Mode" which the default was "ON". This is when you hit the green "Auto" button on the dash, it runs your compressor. Other wise, you have to go into your climate page on the NAV screen and manually select to turn on the A/C compressor.
That is the way I set my car up. I don't want it to run the compressor until I turn it on on the hot summer days.
Old 10-25-14, 07:03 PM
ceads9
ceads9's Avatar
Man you are good ,,,airman . You know it all!
Old 10-27-14, 07:15 AM
nht48823
nht48823's Avatar
Thank you TheAirman! everything has been on factory default settings - I checked your suggestions and they are set as "ON" - the only thing I got confused is the orange light, now that I notice the rear defroster is orange also. I am not sure why would Lexus would make that Orange and all the other green. maybe to confuse me i guess.
Thanks
MattBianco
LX - 3rd Gen (2008-2021)
02-27-16 07:11 PM
RDLGX
RX - 3rd Gen (2010-2015)
09-10-15 06:26 AM
ThumperPup
ES - 5th Gen (2007-2012)
11-24-14 07:19 AM
provlima
09-10-12 07:59 PM
WoodldsMac
15
02-23-09 02:29 PM
Quick Reply: front defroster
