HS 250h Model (2010-2012)
Rear dome light bulb LED replacement
Old 02-17-14, 06:14 PM
eross1981
eross1981's Avatar
Default Rear dome light bulb LED replacement
Has anyone replaced the rear dome light with a festoon LED equivalent? I've ordered 3 types (2 Chinese, and Philips) and none fit:
Cutequeen White 31mm(1.25") 12-SMD 12V Festoon Dome Light LED Bulbs DE3175 DE3021 DE3022 3175(pack of 4) : Amazon.com : Automotive Cutequeen White 31mm(1.25") 12-SMD 12V Festoon Dome Light LED Bulbs DE3175 DE3021 DE3022 3175(pack of 4) : Amazon.com : Automotive
Amazon.com: Cutequeen White 31mm(1.25") 5050 4-SMD 12V Festoon Dome Light LED Bulbs DE3175 DE3021 DE3022 3175(pack of 2): Automotive Amazon.com: Cutequeen White 31mm(1.25") 5050 4-SMD 12V Festoon Dome Light LED Bulbs DE3175 DE3021 DE3022 3175(pack of 2): Automotive
Philips 129416000KX1 XtremeVision 30mm 12V Festoon LED Interior/Exterior Retrofit Bulb : Amazon.com : Automotive Philips 129416000KX1 XtremeVision 30mm 12V Festoon LED Interior/Exterior Retrofit Bulb : Amazon.com : Automotive
Not sure if it's a Lexus thing or if it's an HS250/CT200h thing, but there's not much free play with one of the contacts within the housing. As a result, only festoon bulbs with tapered ends will fit. Taken from 4runner.org
Any ideas or alternatives?
Old 02-23-14, 03:07 AM
TheAirman
TheAirman's Avatar
Try here:
https://www.clublexus.com/forums/hs-...t-upgrade.html
Usually those puny little bulbs don't offer much light for a dome replacement. You need one with lots of lumens.
As you can see, the thin dome light LED from that company uses a festoon type connector. I can't remember if its smooth or pointed on the ends, but I know what you are talking about. It seems like some of the connectors for the festoon bulbs in Japanese cars have those little holes in them that hold the bulb that seem out of line or something, and not all bulbs fit them just right. In that case, I just filed the end until it did fit.
Old 02-23-14, 09:15 AM
eross1981
eross1981's Avatar
Yeah, I'll most likely just file down the bulb contact then. No problems replacing the festoon bulb with an LED one on a 2007 Corolla and a 2010 Forester, but there was plenty of room to bend the contacts within the housing.
DJ TANTRA
Lighting
57
04-07-15 04:26 PM
satz
12-24-12 06:08 AM
Wald GS
GS - 1st Gen (1993-1997)
12-16-09 02:27 AM
triplecore
11-04-08 05:34 AM
Quick Reply: Rear dome light bulb LED replacement
